My Custom Cards for Minimalist UI
Just a name/label and icon. I have been using the inbuilt navigation card. Today i swapped to your scene and status card, and thoight a nav card in a similar style (icon left, low) would look good. I tried for an hour or two to mess about with the template. I got it to be an oval shape before i gave up haha :wink:
added navigation cards (normal style and icon only) to dev git,
docs here and here
@andyblac, just discovered your cards and absolutely love them! Excellently documented as well. Thank you!
I have a question around the custom room card - is there a way to have the room card color be grey when any of the room entities (light group for example) are off and only be colored when they are on? I feel the point of the “ulm_custom_card_andyblac_room_color_on” variable is to achieve this but I can’t seem to get it to work.
hi, thanks and yes, just add entity: xxxxx.xxxxx in the main section of the card, use any entity as you want.
I.e. in this example entity: cover.garge_roller_door is the controlling room card entity. I use long action to open more-info so I can long tap on the room card to open the more info dialog of my garage door.
  - type: custom:button-card
    view_layout:
      grid-area: room3
    template:
      - andyblac_card_room
      - garage-door_animation
    tap_action:
      action: navigate
      navigation_path: garage
    hold_action:
      action: more-info
    variables:
      andyblac_card_room_area_id: garage
      andyblac_card_room_color: rgb(133, 173, 173)
      sensor_1:
        entity_id: binary_sensor.garage_door
      sensor_2:
        entity_id: binary_sensor.garage_motion_sensor_occupancy
        templates:
          - motion_animation
      entity_3:
        entity_id: light.garage_lights
        andyblac_card_room_icon_color_on: amber
Ah perfect! That worked, thank you. And am I right in saying that its only the room icon that lights up and not the background? The code I’m using is below (I’ve removed toggle action and the view_layout for better readability!
    template:
      - custom_card_andyblac_room
    icon: mdi:sofa
    entity: light.livingroom_lights
    variables:
      ulm_custom_card_andyblac_room_use_small_label_font: true
      ulm_custom_card_andyblac_room_color_on: yellow
      sensor_label_1: sensor.living_room_air_purifier_temperature
      entity_2:
        entity_id: light.livingroom_lights
        icon: mdi:floor-lamp
        ulm_custom_card_andyblac_room_use_light_color: true
        action: toggle
yes, that correct, If you want the background to support color_on support add a feature request in my GitHub page, and I’ll see what I can do.
Super! Will do that, thank you for the quick replies! :slight_smile:
Hi Andy, congratulations on your work. I’m not very good with code. I’m trying to create a dashboard like yours in the picture. How did you put the badges of the people next to each other? Could you share the code with me?
sure, here my code from my dashboard
  - type: horizontal-stack
    cards:
        template: andyblac_card_person
        entity: person.andy
        variables:
          andyblac_card_person_use_entity_picture: true
          ulm_address: device_tracker.andys_iphone_icloudv3
          andyblac_card_person_eta: sensor.andys_iphone_icloudv3_zone_distance
          battery:
            entity_id: sensor.andys_iphone_icloudv3_battery
        entity: person.christine
        variables:
          andyblac_card_person_icon: mdi:face-woman
          ulm_address: device_tracker.christines_iphone_icloudv3
          andyblac_card_person_eta: sensor.christines_iphone_icloudv3_zone_distance
          battery:
            entity_id: sensor.christines_iphone_icloudv3_battery
          battery_2:
            entity_id: sensor.christines_apple_watch_se_icloudv3_battery
ciao andy , mi sapresti dire da questo codice come faccio a cambiare il colore delle scritte sotto l’orologio? perche con il tema chiaro mi vengono bianche e quindi non si vedono
  • type: custom:button-card
    entity: sensor.time
    layout: vertical
    name: ‘[[[ return states[’‘sensor.data_italiana’‘].state; ]]]’
    extra_styles: >
    #flip {height:24px;overflow:hidden;} #flip > div > div
    {color:#fff;height:24px;margin-bottom:24px;display:inline-block;} #flip
    div:first-child {animation: show 20s linear infinite;} #flipper p
    {position:fixed;color:#999; } @keyframes show {
    100% {margin-top:-192px;}
    91% {margin-top:-140px;}
    78% {margin-top:-140px;}
    65% {margin-top:-92px;}
    52% {margin-top:-92px;}
    39% {margin-top:-48px;}
    26% {margin-top:-48px;}
    13% {margin-top:0px;}
    0% {margin-top:0px;}}
    label: >-
    [[[return `
    Temp Esterna: 🌡${states['sensor.meter_bagno'].state}°
    ${states['sensor.meter_bagno'].state}%</div></div><div><div> Temp Interna:
    💧${states['sensor.meter_bagno'].state}%</div></div><div><div> Consumo:
    ☀${states['sensor.meter_bagno'].state}W</div></div><div><div> Bridge Zigbee:
    ${states['sensor.meter_bagno'].state}</div></div><div><div>`]]]
    show_icon: false
    show_label: true
    show_name: true
    show_state: true
    styles:
    card:
    - height: 100px
    state:
    - font-size: 200%
    - font-weight: bold
    - justify-self: center
    label:
    - font-size: 90%
    - color: green
    name:
    - font-size: 120%
    tap_action:
    action: none
Screenshot 2024-08-19 162423
codice con sintassi corretta
entity: sensor.time
layout: vertical
name: '[[[ return states[''sensor.data_italiana''].state; ]]]'
extra_styles: >
label: >-
  [[[return `<div id=flipper><div id=flip><div><div>
  Temp Esterna: 🌡${states['sensor.tempesterna_temperature'].state}°
  💧${states['sensor.tempesterna_humidity'].state}%</div></div><div><div> Temp
  Interna: 🌡${states['sensor.tempcucina_temperature'].state}°
  💧${states['sensor.tempcucina_humidity'].state}%</div></div><div><div>
  Consumo:
  ☀${states['sensor.potenza_attiva_prelevata_istantanea'].state}W</div></div><div><div>
  Bridge Zigbee:
  ${states['sensor.zigbee2mqtt_bridge_state'].state}</div></div><div><div>`]]]
show_icon: false
show_label: true
show_name: true
show_state: true
styles:
  card:
    - height: 100px
  state:
    - font-size: 200%
    - font-weight: bold
  label:
    - font-size: 90%
    - color: green
  name:
    - font-size: 120%
tap_action:
  action: none
sorry, I do not speak Italian, Can you ask the question in English please.
Andy.
Hi @andyblac ,
thanks again for your great work.
I have the following question. I have integrated a device with mqtt. the device has several attributes. in the home.yaml, for the maps of the individual rooms I would like to display one of the attributes as sensor_label_1. Currently it looks like this
sensor_label_1: climate.bosch_hkt_gaming (this is the entity)
It has worked up to this point, but not with the desired information. At this point I would like to display the attrubute current_temperature. something like this
      attribute: current_temperature
Can you help me with the code at this point?
Many thanks in advance.
hi, you’ll need to create a new sensor for this entity attribute, you can do this by
going to Settings -> Devices & Services
Click on the Helpers tab at top
click on CREATE HELPER button at bottom right of page
choose Template
Then choose Template a sensor
then fill in the info like my example screen shot bellow, but use your entity and attributes names correctly
the name will become the new sensor entity name.
:wink:
https://translate.google.com/?sl=auto&tl=en&text=ciao%20andy%20%2C%20mi%20sapresti%20dire%20da%20questo%20codice%20come%20faccio%20a%20cambiare%20il%20colore%20delle%20scritte%20sotto%20l’orologio%3F%20perche%20con%20il%20tema%20chiaro%20mi%20vengono%20bianche%20e%20quindi%20non%20si%20vedono&op=translate
change this to suite color:#fff fff = white, the code is RGB 0 to f for each colour ie 00f would be green.
@andyblac I can’t get past adding the repository to access my-card. Am I missing something?
Hi everyone!
I am following this guide
I just couldn’t find the point Include custom card resources it's depending on. For me it now looks like this:
I have adapted the example code with my entities. I now get the error message
configuration error
-no type specified
What am I doing wrong?
    template: custom_card_andyblac_room
    tap_action:
      action: navigate
      navigation_path: bathroom
    variables:
      ulm_custom_card_andyblac_room_color: blue
      sensor_label_1: sensor.buro_temperatur_feuchtesensor_luftfeuchtigkeit
      sensor_label_2: sensor.buro_temperatur_feuchtesensor_temperatur
      custom_2:
        entity_id: climate.buro_temperatur_feuchtesensor
      entity_3:
        entity_id: light.deckenventilator_buro
        ulm_custom_card_andyblac_room_icon_color_on: yellow
      entity_4:
        entity_id: fan.deckenventilator_buro
        ulm_custom_card_andyblac_room_icon_color_on: rgb(77, 195, 255)
        templates:
          - fan_animation
Hi @andyblac,
I’m trying to change the color of a thermometer based on its value.
I would like to address it with the use of a template.
I tried so many versions, but here is the last one that I tried:
custom_color_temp_icon:
  styles:
    icon:
      - color: >
          if (entity && entity.state) {
            const value = parseFloat(entity.state);
            if (value > 27) return 'red';
            else if (value <= 19) return 'blue';
            else return 'green';
          return 'grey';
And then I call it here:
      entity_2:
        entity_id: sensor.temperature_humidity_sensor_1fb1_temperature
        tap_action:
          action: more-info
        templates:
          - custom_color_temp_icon
But I must be missing something, as it does not work.
Thx for your attention.
And also thx for this great custom card.
Rgds,
JP
try template not templates
scratch that. hmm, if you put a simple return grey in the template does it override the colour ?
also how are you adding the custom template in the yaml please provide the yaml.
