Can you post a screenshot from the developer tools states of the sensor
for example like this:
just pushed a fix to the dev git, please try.
with dev the problem is fix
great thanks for reporting back.
Don’t you think it’s better to use the device’s group attribute instead of creating an area called groups?
i use area groups
then i can dump anything in there I want to ignore ( i have several groups of lights), it can be called anything you want, just edit the ignore area in the sensor.
BTW: climate should be in the dev test file you got,
- type: custom:button-card
view_layout:
grid-area: room5
template:
- custom_card_andyblac_room
icon: mdi:sofa
tap_action:
action: navigate
navigation_path: lounge
hold_action:
action: "more-info"
variables:
ulm_custom_card_andyblac_room_color: yellow
sensor_label_1: sensor.wiser_lts_temperature_lounge
sensor_label_2: sensor.wiser_lts_humidity_lounge
climate:
entity_id: climate.wiser_lounge
sensor_1:
entity_id: binary_sensor.lounge_door_contact
Pretty cool!!!
Thank you!
it’s a fas: …from https://fontawesome.com/
can you do a short video of the issue ?, popups seems ok here. as for the overlap, hmm what do you think we should do ? maybe reduce the room icon slightly ?
It seems to me more like a problem with the centering of the fas: icon …it seems more moved to the left and down
probably reduce the room icon when using fas - that’s the right way
How can I send a video here?
ether a GIFF or upload to a free hosting site and post link
hmm strange, i understand it was working OK before 2023.11 update ?, maybe report the issue on bowser_mod integration GitHub - thomasloven/hass-browser_mod: 🔹 A Home Assistant integration to turn your browser into a controllable entity and media player
before the update it definitely worked. in those days however I was also working on the dashboard!
