I’m a fan of Google Cloud TTS, but the problem that “we only use 1 voice name at the same time”, that’s now I’m create the first component Google Cloud TTS to do it
This is the example of speaking using this Service
script:
gg_reading_01: #May be from your script name
sequence:
- service: tts_ggcloud.say
data_template:
entity_id: media_player.van_phong #May be from your entity speaker
message: "Your text input here" #May be from your input_text
speed: '1.0' #May be from your input_number
pitch: '0' #May be from your input_number
language: "vi-VN" #May be from your input_select
voice_name: "vi-VN-Wavenet-A" #May be from your input_select
By the looks of it, it enables a TTS service built on more natural sounding wavenet voices than the default google tts service (which I think uses google translate).
Benefits are better sounding, more control over intonation, delays etc, lots of voices to choose from and different nationalities.
It probably needs a google API key, which is limited to a certain volume of characters before you have to pay. However, that limit is pretty high, I use it through node-red for announcements around the house and never come close.
If I read it right, it’s 1m characters per month before you pay, that includes all the characters in the message (e.g. control characters, headers etc.) not just those that are spoken.
This custom component enable multiple Google Cloud TTS Voice at the same time, for example with Vietnamese language (languageCode = vi-VN) we can select 1 of 8 voices at the same time
