I have a issue. I use your files but when I click it shows me only the title and not the rest. What can I do?
Please post a screenshot to better understand whats happening.
Also was it working fine on browser mod v1?
works in my case also perfectly. maybe stick to the installation instructions of browser mod v2 if you get errors: GitHub - thomasloven/hass-browser_mod: 🔹 A Home Assistant integration to turn your browser into a controllable entity - and also an audio player
Oh on your phone its like that I didn’t check that before!. I tried it on my phone now and nothing was popping up at first.
What I did to fix it was, in the HA app goto setting > companion app > enable webview remote debugging, then fully close down Home assistant app and started it up again and it worked.
Im not sure if that is the best way to do it but basically I wanted my HA app to clear the cache as that is always the cause of these issues.
After that turn off webview remote debugging
Thank you, but the problem persist. I have the problem on the phone but also on the pc
Yes I have. I copied the code from yaml to developer - > services
And launching the service from there, everything works fine. I don’t know why in the front-end doesn’t work
Thx a lot. Works great with me, once I did a full deinstallation of Browser mod V1, first in HA-> Settings-> integration-de-install , then de-installation in HACS (via the 3 dot icon) , removed browser_mod from configuration.yaml , restart HA and clear the cache. Then standard install of browser_mod
I’m not sure what else more to suggest.
If you want you could revert back to browser_mod v1 as I mentioned here My Garden Irrigation - #1632 by ahmaddxb
Then you could overwrite your files back from the original github project GitHub - kloggy/HA-Irrigation-Version2
Your schedules doesn’t work because you’ve checked adjust for rainfall, remove it and it will work. I had the same problem
The files have been updated for browser-mod 2.
Many thanks to @ahmaddxb for making the changes while I was away. I still don’t know how to use GitHub properly so I hope I merged it correctly…
I have not found a way to change the font of the popup header so there are a few lines of ‘style’ that don’t do anything (or have any other effect). If anyone works out how to do this before me, please post the solution!
I’m not sure but maybe I over indented the styles and they dont work. I don’t have a reference what it should look like compared to what I have now.
Works for me, after:
Unfortunately not,
i’ve tried all solutions but nothing happens.
No problem with manual mode, big problems in automatic mode.
I don’t know why, someone could you help me?
This is my actual configuration:
Valve’s names:
No, history totals showed:
I’ve already created input.text_notifications…but it’s in unknown status
browser_mod ver.2 ok!
Thanks in advance,
Alessandro
Just a quick reply…
You seem to have conflicting cycle start times?
Click on the icon I think it gives some help (it is so long since I wrote this and I have never had it appear for me )
Hi klogg,
i’ve already seen it, but it seems a mistake.
If you take a look at the schedule you can see there isn’t any conflict in cycles because Giardino cycle runs every Mon/Wed/Fri and Sun while Goccia cycle runs every Tue/Thu and Sat…both cycles runs in different days.
Even if it were true, it should irrigate the garden cycle but actually both cycles doesn’t start.
You might have found a bug!
Can you see if it works with the cycles running at different times?
