I use a docker container called Organizr to neatly display all of the programs I run on my server through one interface. I have used it for a while with no issues. I few days ago I updated home assistant for the first time in about 5 months. Now home assistant will not work in the iFrame on my Organizr site. It only says: "homeassistant.mydomain.com refused to connect". When i check the developer console in google crome it shows the following error: Refused to display 'https://homeassistant.mydomain.com/' in a frame because it set 'X-Frame-Options' to 'sameorigin'.
So I assume that the default X-Frame-Option was changed in an update for some security reason or something. Is there a way for me to change it back so I can use homeassistant in an iFrame?
Hijacking because I use the same setup using organizr and HA in iFrame.
I updated from 2024.1 to .2 then it only shows the HA Logo (like its loading the dashboard). Working fine without iFrame.
Already using use_x_frame_options: false.
Not the same setup, but exactly the same symptoms.
I have 2 separate HA installs on Raspberry Pi 4s. I have accessed one page from the other system, this applies to both installs. To make the iframe content visible from outside network also, there referencing urls were the ones I am using in duckdns.org.
This used to work fine. Last autumn at some point there was a change mentioned above, due to which it was needed to add the next line to configuration.yaml:
use_x_frame_options: false under the http:
…after which it worked just fine. It is still there.
But know, and nothing else has been changed, I get only the HA logo:
I also have the exact same problem since the last update. I updated both the OS and Core at the same time so I’m not sure which one caused it.
I am actively looking for a solution. I’m also using duckdns.org, not sure it’s related but more info is always better.
to be clear I also have the “use_x_frame_options” set to false. I checked the breaking changes from the update but did not see anything about iframes
