After a lot of work and research i managed to make it all work really stable and give it a decent easy to use look.
The styling is heavily customized trough CSS using card_modder the theme i use has little to nothing to do with the final look. Some custom component have been modified as well to serve my needs in term of style…
I am sharing my lovelace.yaml file for reference that you can download here:
Ok this the final look i wanted some sort of translucent frosted tinted glass with a nice little shadow.
To achieve this you need to modify each card with CSS code using (card_modder) custom card that you can download here: https://github.com/thomasloven/lovelace-card-modder.
Thanks to Thomas for sharing it.
Very awesome interface! I’m a bit new to HA and finally getting enough components put together and have a decent start at my Lovelace UI. How did you get the light entities to show the dimmer on the UI without having to click it? (In addition to the switch on/off)?
Inspired by that second card, I downloaded Sweet Home 3D (it’s great!). Is your view dynamic? The lights seem to be on/off in your view, depending on the HA state? How have you implemented that?
Hi @vjmindlab firstly awesome work love the rounded corners will be using that for my my own setup so cheers for the inspiration. I see that you have implemented power consumption, I have been trying to tackle this myself and wondered if you could share your config or repo so I can see how you have gone about it. I am 99% there just having trouble with the stats sensors retaining data for previous month etc. I was going to go try pulling it from influx tonight but saw this post.
On a side note, it appears you have a C02 sensor (on conditions card with temps, etc) - may I ask what sensor you are using. I want c02 sensors inside my house, but they seem very expensive…
