My Hass.io and Lovelace setup Updated
Did you apply author’s theme My Hass.io and Lovelace setup Updated ?
WOW Thanks! missed these part…
Great work! Thanks a lot!
How did you change the color of the thermometer icon?
I see blue and green, i assume that he change with the value of the sensor?
hello @vjmindlab how did you save the parts in transparent png files? I am trying to do it but I still get the white background in my floorplan.
Also from your code it seems like you have display the lightened floorplan image and then put the ones without light on top? is that correct?
thanks.
I use Photoshop and save as transparent PNG
And yes it is correct base image is lights on and i overlay the light off image
Working on a new look
Please share,
This is in my opinion the perfect theme between day and night!
thanks i’m almost done will soon make a post to share
Shared Sharing my new theme setup
Just started with HA and being a bit underwhelmed with the initial look I had a look for themes and came across this and love it!
Excuse my basic understanding but is it not as simple as copying the ui-lovelace.yaml file to the config directory along with the resources and then just put the below in the configuration.yaml file? I get loads of dictionary errors if I only follow those two steps so guessing I’m missing something key :frowning:
frontend:
  themes: !include ui-lovelace.yaml
