My Hass.io have wrong date
My Hass.io in log file show now is 02:29 of 19 Sept 2019
But now is UTC +1 time 19:28 of 05 Oct 2019
Why date and hour is wrong?
No access to NTP server?
How can I solve it in Hass.io?
Does it have access to the internet?
Yes, but I suspect firewall do not opened port UDP 123 for NTP
could be this the problem?
quite likely
I opened port 123 in the router and restarted the router… and finally I solved the problem
Time sync problem cause a lot of problems…one of this is that you are unable to upgrade Hassio and history and logbook do not works.
You don’t say what hardware you are using, but I am guessing rpi. They do not have a real time clock (RTC) so need access to ntp.
