I’ve already check other topic, like My Hass.io have wrong date but with no success
I have an hassio
Core Versione core-2021.8.8
Supervisor Versione supervisor-2021.06.8
Home Assistant OS 6.5
via ssh i try date command and i get
Fri Jun 25 14:50:54 CEST 2021
(now is, on my time zone, November 11th, 22:44)
I read on ohter topic to be sure that hassio can connect to a NTP server. I suppose it can, because it 's correctly connected to internet ( can pig without problem, for example, pool.ntp.org)
I suppose my ISP doesn’t block the udp 123 port, neither my router, because on my windows pc on the same lan if I use the command w32tm /monitor /computers:pool.ntp.org i get what i suppose a good ouput
pool.ntp.org[184.105.182.16:123]:
ICMP: 198ms ritardo
NTP: -0.7915331s differenza di tempo dall'orologio locale
RefID: clock.sjc.he.net [216.218.254.202]
Strato: 2
so now what i can do?
I have to correct the time because i have many problem (for example i can’t update)
