My Lovelace Plugins
Still not working :frowning:
Sorry, spoke to soon, cleared cache and it seems to be working. Thanks for your patience!
Hi Thomas,
When using this, are you then able to select which order you want the cards in?
The “More info on github” describes how cards are ordered, and what you can do to change that.
 Maybe you can answer this one as well in addition to the above described.
The standard ui or lovelace, you can’t change the order right?
Right now it looks like it just puts in the cards how it wants.
The link describes the rules, and how they can be bent slightly. You can’t get more control over it than that.
If that doesn’t answer your question I don’t understand what you are asking.
Looks like fold-entity-row doesn’t work in 0.81.5.
EDIT: Seems it doesn’t work with the section entity.
  - type: custom:fold-entity-row
    head:
      type: section
      label: Lights
Using some other entity as head works.
EDIT2: Fixed in 0.82.0b1
How did you get it to work? I run latest beta too and canÂŽt load the fold-entity.
I have this in log:
2018-11-03 21:10:04 ERROR (MainThread) [frontend.js.latest.201811031] https:/HASS/local/fold-entity-row.js:7:1 Uncaught SyntaxError: Unexpected token <
js file seems to be correct
Just updated to 0.82.0b1
        head:
          type: section
          label: CONFIG
        items:
          - automation.motion_esp8266_02
          - variable.motion_esp8266_02_delay
          - input_number.motion_light_esp8266_02
          - sensor.hyperion_color
Browser cache?
Do you have any groups using this?
I tried with the config in the readme:
type: entities
title: Folding groups
entities:
  • type: custom:fold-entity-row
    head: group.all_lights
    head: group.all_scripts
    head: group.all_automations
and got this error
Just a quick test, works.
      - type: entities
        entities:
Auswahl_151
Thanks for testing,
strange I have this error.
I prepared fold-entity-row for the beta a few days ago. If it doesn’t work, make sure you have the latest version from github.
I just took this one
wget https://raw.githubusercontent.com/thomasloven/lovelace-fold-entity-row/master/fold-entity-row.js
Its 2 days old and put it in my www (as I did with the older one)
Just updated the fold-entity-row.js to the latest, and now I can’t toggle the lights anymore. when I switch a light toggle it switches back after a second or so.
My lovelace code is:
  - type: vertical-stack
    cards:
      - type: entities
        entities:
          - type: "custom:fold-entity-row"
            head: group.upstairs
      - type: entities
        entities:
          - head: group.downstairs
      - type: entities
        entities:
          - head: group.lounge
      - type: entities
        entities:
          - head: group.kitchen
Any ideas?
I assume you are on 0.81.4 ?
This is fixed in 0.81.5. Has nothing to do with the fold-entity-row.
Anyone got a clue how to debug this?
All other custom lovelace seems to work so it is a bit strange, can it be something with javascript?
I have this in config:
javascript_version: latest
Nope - I’m running 81.5
I think it was a browser cache problem - cleared and working now.
Not sure, but i think someone on Discord had the same issue.
Download cache problems. Have you downloaded the file in raw mode once again?
