@thomasloven I have in log error after opening/closing HA side panel:
https://_redacted_/local/lovelace/layout-card.js?ver=c8847a:55:28 Uncaught TypeError: Cannot read property 'id' of null
I am getting this error when trying to use the â- break:â function in the layout-card -> Uncaught TypeError: Cannot read property âstartsWithâ of undefined.
Edit: Turns out I was using a colon after â- breakâ which shouldnât have been there however now when trying this with the modder-card i am hitting this error -> Uncaught TypeError: this.card.setConfig is not a function
Edit#2 After struggling trying to get this to work with the modder-card for a couple of hours it seems all I needed to do was go to another tab within lovelace and immediately go back and just like that it worked. Iâve had this trouble with other cards but usually I get the red-info card but in this case all I got was the error message in the lower left corner and I assumed it wasnât working. Another lesson learned, hopefully this helps someone else.
Should be fixed now.
I have a lot of errors in system log when resizing the browserâs window:
/local/custom-lovelace/layout-card/layout-card.js:69:1 TypeError: this.$ is undefined
Now i workaround it by adding
if (typeof(this.$) != "undefined")
is it OK?
Thank you, it workâs great. About toggle lock entity row - it works only with âswitchâ type. What about the âinput_numberâ? For now it convertâs the âinput_numberâ to âswitchââŠ
@thomasloven After upgrade HA to 0.82 when I go ftom dev-info page to overview page I have in log this error for layout-card (browser cache cleaned):
https://_redacted_/local/lovelace/layout-card.js?ver=dfdfe8:69:27 Uncaught TypeError: Cannot read property 'columns' of undefined
My config:
- id: home
icon: mdi:home
title: 'Pomieszczenia'
panel: true
cards:
- type: custom:layout-card
cards:
Great new card, thanks!!
One suggestion if itâs possible please - could there be an option for âup to column countâ or âmaximum column countâ?
For example, I like to use the horizontal layout, and on my 24" monitor it automatically results in 5 columns. I would like to reduce this to 4 columns but donât want to force this to be the case when viewing from a smaller display such as a mobile phone. The result would be auto column count by screen size, up to and no more than 4 columns on larger screens.
Happy to put this request in GitHub if you prefer?
@Bieniu The TypeError should be fixed now.
@jarrah Try the newest version and config option max_columns: (undocumented).
Great card, the max_colums: is exactly what I am looking for.
My aim is to get three columns of cards in a row, but preferrably without forcing 3 (since the cards get to compressed on mobile.)
I can not get it to work however.
Still get 5 columns, and a - break just introduce a blank column before it put the next card in column 5
Get the same issue as when trying to use only layout: horizontal and then - break after the first 3
ui-lovelace.yaml
- type: iframe âŠ
- type: iframe âŠ
- type: iframe âŠ
- break
#Bussar
- type: entities
âŠ
- entities:
âŠ
- type: gauge
Try nowâŠ
Works perfectly!
Good that it was nothing to see in the diff
Superb, works a treat, thanks!
Hey Thomas,
You really make some really cool but also very handy cards!!!
One question through - where should the layout card be saved? Under /local/ and do I need to add anything to my resources?
Hereâs a good explanation on how to install, use and debug lovelace plugins:
Also, read this to find out where to put the files:
Awesome!
What is needed to get the on/off/weekdays options to work?
I donât know⊠some automations⊠appdaemon if you feel comfortable with that, perhaps?
Itâs just a number of dummy switches and inputs I made for demonstration. They arenât connected to anything
Hey,
how can you track your skoda? I thought the skoda connect plugin doesnât exist!
With satellite
Hi
Iâm trying to use the lovelace-player plug-in but i canât get it to work on my android device.
Iâm successfully able to retrieve the device id for chrome then update the lovelace-player-config.js with it as below :
setTimeout(function() {
// Add your bindings here
// Example:
LovelacePlayer.bind("media_player.emilie_bedroom", "00db073-5faba8b1");
// Remove this line when you found your Device ID
//LovelacePlayer.debug();
}, 200);
The media player is visible at /dev-state in Hass but always idle. If i try to interact with it (on/off , next track), i get the following error in the log.
Error doing job: Task exception was never retrieved
File "/data/data/com.termux/files/usr/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 226, in _handle_service_platform_call
await func(entity, data)
File "/data/data/com.termux/files/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/data/data/com.termux/files/usr/lib/python3.6/site-packages/homeassistant/components/media_player/__init__.py", line 504, in mute_volume
raise NotImplementedError()
NotImplementedError
Any hint how to solve this ?
edit: solved - error in the device_id.
Thank you
