My Lovelace Plugins
I use the card-modder (attachment code) … and it does not show the design background
  - type: custom:card-modder
    card:
      type: custom:auto-entities
      show_empty: false
      card:
        type: entities
        title: Lights on
        show_header_toggle: false
      filter:
        include:
          - domain: light
        exclude:
        - state: "off"
        - state: "unavailable"
    style:
      background-image: url("/local/lovelace/background/cardbackk.png")
      background-repeat: no-repeat
      background-color: rgba(50,50,50,0.3)
      background-size: 100% 68px
      border-radius: 20px
      border: solid 1px rgba(100,100,100,0.3)
      box-shadow: 3px 3px rgba(0,0,0,0.4)
      overflow: hidden
is the extra ‘k’ supposed to be in the file name?
Yes, this is the correct name for the background image. I use the same name for other places
Thanks @thomasloven. Working great again. I had to manually update it. It’s been over 6 hours since you posted the update, and card tracker is still showing the previous version as the latest, and wants me to install that. :face_with_symbols_over_mouth: Not sure what’s happening there.
Is card tracker playing up for anyone else?
yes I don’t see the auto-entity card in the tracker either
Updater usually runs once a day I think. https://github.com/custom-cards/information/blob/master/repos.json
@ludeeus does a job need to be kicked off?
That would make sense based on what I see. That’s a shame. Should be able to click the check button and it checks the latest versions of each card installed.
That is correct @iantrich, Im working on getting it down to hourly
What time does it run at the moment? And what time zone?
fold-entity-row
Is it possible to change the name: and icon: of the head:?
for example, but not like this, it doesn’t work
        - type: custom:fold-entity-row
          head: sensor.tasmota_earliest_installed_version
            - name: Sonoff / Tasmota Earliest Installed Version
            - icon: mdi:alpha-s-box
          items:
            - entity: sensor.sonoff01_firmware
Do it the same way you would if it was a normal entity in an entities card.
Do you mean like this, because it doesn’t work.
(So obviously not)
              head:
                - entity: sensor.tasmota_earliest_installed_version
Since head expect only one thing, and not a list, you should remove the dash.
any feedback on those questions?
  1. Is there a way to use auto-entity card with media control or custom miniplayer cards? (ex: display all media-player.plex* playing in mini player or media control cards, works fine in entity mode)
  2. Could you show us an example of the lovelace code to combine auto-entity with fold entity? Tried a few ways but cannot make this work…
  3. Is it normal it doesn’t show up in the custom updater card?
  4. Is there a sort option for auto-entity cards?
Thanks in advance, love yours cards|
Very nice! Could we get the Lovelace yaml snippet to make the screen shot you attached? Struggling to nest this inside the folding-entity like you display.
  1. Not at this point. Adding several cards in a bunch is a bit tough, due to the layouting and stuff…
  2. I’ve added the code to the end of the readme on github (ping @jwelter, too)
  3. As discussed right between your two messages, the custom tracker updates once per day.
  4. Not yet. I’ll make sure to add one, though.
Thanks, this is great stuff!
card-loader
Some people have experienced problems with custom cards that wrap other custom cards (such as putting mini-media-player in vertical-stack-in-card.
I haven’t experienced this myself, so I can’t test this, but I believe card-loader could be used as a workaround until the card developers fix it.
Thanks for that… I would never in a million years have stumbled on that code. Cheers.
Hi Thomas -
Does this support putting a attribute on the second_line display? For example battery_level for zwave devices for the battery check would be helpful?
