Getting same error as you, switching tabs (view) error is gone. Card modder is causing this error.
yes… add this to the card:
show_header_toggle: false
So I added “show_header_toggle: false” in my ui-lovelace.yaml like this:
- type: entities
entities:
- entity: group.chargers
type: custom:folding-group-entity-row
Didn’t work. Should “show_header_toggle: false” be added elsewhere?
move it down under entities:
Thank you Sir!
David, I appreciate your help so far. I’ve tried applying the show_header_toggle four different ways and they all return the same card. Any other ideas or is there some other setting I should try applying/changing?
#1
- type: entities
entities:
#2
- type: entities
entities:
#3
- type: entities
entities:
group_config:
#4
- type: entities
entities:
config:
Here my switches one:
- title: Lights & Switches
icon: mdi:power
cards:
- type: vertical-stack
cards:
- type: entities
title: Light
entities:
- light.dining
- light.lounge
- light.yeelight_white_34ce00887db6
- light.yeelight_white_34ce00882e27
- light.office_light_group
- light.office
- light.desk
- type: entities
title: Switch
entities:
- switch.coffee_maker
- switch.home_assistant
- switch.hifi
- switch.vpn_router
- switch.toothbrush
and here’s what it looks like:
Without the toggle: false, I would have a slider button next to the Light & Switch titles.
Hi @thomasloven , I’m having issues with the generator. My shell command config is as follows (running HassIO):
shell_command:
lovelace_gen: 'python3 /config/lovelace-gen.py'
I’m getting this error:
2018-10-13 07:49:40 ERROR (MainThread) [homeassistant.components.shell_command] Error running command:
python3 /config/lovelace-gen.py, return code: 1
Any idea how to fix this?
Nevermind, I wgetted the wrong file from github.
How do you get sensor side by side in the panel?
I’ve made several attempt but I get them always one under the other.
EDIT: Nevermind… I forgot about the Glance card
Ah I see the confusion, @DavidFW1960. I was specifically asking about hiding the toggles for the folding group entity rows. Thanks for your help anyways. Maybe @thomasloven can help?
@dylpickles1234 I am having the exact opposite problem!
I am using the folding_group_entity_row and I can’t seem to get the toggle to show. I am trying to use the auto-created group group.all_automations
- type: entities
title: Automations
entities:
- entity: group.all_automations
Edit: This appears to be a general issue with the entities
card. I opened an issue on GitHub here.
What’s the card you are trying to mod?
Edit: Never mind. I see from the screenshots that it’s button-card…
Does it work (with exactly the same configuration) when not wrapped in card-modder?
Not for now.
cards:
- type: horizontal-stack
cards:
- type: "custom:button-card"
entity: group.svjetla
icon: mdi:lightbulb-outline
color: auto
action: more_info
default_color: rgb(255, 233, 155)
color_type: icon
entity: light.rgb_traka
icon: mdi:palette
color: auto
color_type: icon
entity: light.luster
icon: mdi:ceiling-light
color: auto
color_type: icon
entity: light.led_traka
icon: mdi:hotel
color: auto
color_type: icon
And this works too:
cards:
cards:
- type: custom:card-modder
card:
action: more_info
show_state: true
style:
- text-transform: none
style:
"background": "#2b2d3199"
border-radius: 12px
color: white
height: 90px
card:
icon: mdi:palette
show_state: false
style:
style:
border-radius: 12px
color: white
height: 90px
card:
show_state: false
style:
style:
border-radius: 12px
color: white
height: 90px
card:
icon: mdi:bed-empty
show_state: false
style:
style:
border-radius: 12px
color: white
height: 90px
But If I refresh ha, or first start it, I get that error, I have to switch tabs for error to disaper.
Really nice interface.
Do you mind to share?
fold-entity-row
I decided I could do better than the folding-group-thing… so here’s fold-entity-row.
It works pretty much the same way, but now you don’t need to rely on home-assistant groups, but can put any entities you want in a foldable section of an entities card.
It will still handle groups if you wish, and you can change options for each entity separately, or all of them at the same time.
Anything that can be put in an entities card can be used as the header or put inside the fold.
Also, it’s now possible to have the fold open by default.
Update:
There’s been a design update
Note that this totally deprecates the folding-group-entity-row, and the repository for that has been renamed to lovelace-fold-entity-row.
It is a breaking update, but readjusting should be easy - and totally worth it.
… and no. Nesting them does not work…
Great change. Can you add as an option possibility to hide folder triangle and move the head entity icon to the left.
Something like that:
