My Lovelace Plugins
I think this might make more sense for that use: https://github.com/home-assistant/home-assistant-polymer/pull/1779#issuecomment-430205102
This is great, thanks
For the new fold-entity-row card, how can I add secondary info to the top item?
For example, when using a group entity it auto populates the list, but I want the group to show the last changed status, but not the entities below.
Edit: Never mind, I just had to add the secondary_info option under the head tag.
looks amazing! do you have a github page where you share the code?
This is a simple label. fold-entity-row is exactly what I’m looking for (possibility hide few entities in one) but I don’t like triangle icon.
So how would you open an close the fold?
By click on the head entity.
Changing the click behavior of the header is kind of hard
How about a design change instead? More Material Design.
Oh yes, in my opinion it looks much better now.
This has finally been fixed.
Would it be hard to make a card that when pressed (or long pressed) can hide or unhide another card?
I’m trying to find a way to have like a toggle (made from an image) that is part of a picture elements card that when pressing say the light image, the fold-entity-row card can appear under the elements card. It’s sort of like a clickable conditional card.
Why not just make the image toggle a switch (mqtt switches can be used as dummies) and display the conditional card depending on it’s state?
Ya that’s what I was thinking to do, but wasn’t sure if it was easier to have a toggle button that pointed to a card to hide it, as to not have too many extra switches and stuff in HA just for UI purposes.
The line between front- and back-end blurs somewhere close to where you are right now
It is very blurry.
To me, UI navigation and operations are all front end tasks where as device / entity operations are back end tasks. I think the goal of lovelace was to separate the devices from the UI, which is where creating a binary switch for ui operations seems like the reverse of that goal.
Getting this error message. I have removed the old js and reference in lovelace. What else can it be?
local/fold-entity-row.js:138:16 Uncaught NotSupportedError: Failed to execute ‘define’ on ‘CustomElementRegistry’: this constructor has already been used with this registry
You’re using a bugged version from a couple of days ago.
Redownload the latest version of the .js file from github and try again.
After updating to HassIO 0.80.2 this morning I now get the below error when I navigate to a page that includes a long_press.
https://xxxxx.duckdns.org:8123/local/custom_ui/long-press.js?v=252428:47:56 Uncaught TypeError: document.querySelector(
).$$ is not a function
any ideas what this is?
I just pushed a new version to github that fixes this.
That’s also - probably - the last change I’ll do to this plugin
Extremely functional! I will use it in applications with alarms, among others.
