i have started to use the card-modder card, but when i give it a background and a color on the entities card the entities get the color that is set but the title of the card stays the default color. i’m i missing something? and with a glance card it works just fine.
style:
"background": "#2b2d3199"
border-radius: 12px
color: white
Folks, you should really use code blocks, otherwise the formatting is all wrong. If you don’t know what a code block is, scroll to the top of this page and read the very first thing you see.
To answer the question here’s a (properly formatted) custom_updater component:
is this new included functionality documented somewhere? It doesn’t look like the Lovelace docs have been updated, nor do I see anything in the blog relating to it. Just wondering if this hold_action can be used elsewhere other than on picture elements…?
This is awesome, nice work!
In the top picture it seems like it’s possible to have an input_select as the head, but I can’t find out how. If it’s possible, can I have the entities in the fold-entity-row change when I select something from the input_select?
can I change the width of the slider-entity-row when on single line? In the old custom-ui I changed the witdh to not cut off some of the light names. Now I have three lights called “Kitchen…”
Hi - did you use CSS styling on the cards, or is it just a background image? Particularly interested in how you got the radius corners and alpha background to the boxes!
There is a problem in 0.81.0 with stacks and lovelace - red screens. This should be fixed tomorrow with 0.81.1 hotfix. It’s not your lovelace file or template rules
