The current HASSOS does not have a build specifically for the NUC.
Sadly, the image I used is no longer supported and the install would not progress using that image as the server-side files are no longer available. Youāll have to wait for an official HassOS NUC image. I saw a tweet a month or two ago showing the developers have a NUC for testing so hopefully itās coming along soon.
Yea, I was doing the same āhunt for the imageā but I ended up just setting up an Ubuntu VM on top of ESXi 6.7 (hosted on my NUC) and using this article to install it. Really is pretty simple and straight forward.
As for the Intel NUC itself, there are some switches for this. It would look like this:
curl -sL https://raw.githubusercontent.com/home-assistant/hassio-build/master/install/hassio_install | bash -s -- -m intel-nuc
I have never actually tried this, but would be curious to know if this works on a pre-installed Linux system running on an Intel NUC.
The switch merely pulls an image designed for the hardware. Itās still sitting on a Linux OS, running in docker. It isnāt even close to the same as the old resinos based hassio.
It actually works even without the nuc switch. Iām running that on Debian stretch.
I installed hass.io on a NUC running Ubuntu 18.04 in Docker in under 20 minutes with not much pre existing knowledge of either Docker or Ubuntu. The biggest challenge was writing the Udev rules (who ever decided to arbitrarily name USB devices in Linux?!?)
System is running rocksolid, consuming around 6 watts and CPU at around 6% load on average
Hej Frank,
Do you have it documented somewhere? I would be interested.
Hi @doubleus
It is really easy! Steps are (roughly):
Install Ubuntu Server 18.04 LTS http://releases.ubuntu.com/18.04/
Install Docker https://linuxconfig.org/how-to-install-docker-on-ubuntu-18-04-bionic-beaver
Install Portainer (as I like a GUI) https://portainer.io/install.html
Install hass.io (I do remember I ran into some issues with dependencies not being found so I manually installed them) https://www.home-assistant.io/hassio/installation/
Write some Udev rules in case you have multiple USB devices http://hintshop.ludvig.co.nz/show/persistent-names-usb-serial-devices/
Profit
Anyone else running Hassio on NUC have trouble when there is a power failure? I have the bios set to start the NUC but HA never recovers. I can ping the device but no frontend or Samba access. Luckily I can still SSH in and the only way to fix it is to reboot the OS. Anyone else seen that?
Mine restarts as soon as power is restoredā¦
Thanks, wonder what mine is doing. Iāll post a log shortly.
Hereās my log. Youāll see it said it was OK but I could not restart HA.
core-ssh:~# hassio ha info
"result": "ok",
"data": {
"version": "0.82.0",
"last_version": "0.82.0",
"machine": "intel-nuc",
"image": "homeassistant/intel-nuc-homeassistant",
"custom": false,
"boot": true,
"port": 8123,
"ssl": false,
"watchdog": true,
"wait_boot": 600
core-ssh:~# hassio ha restart
ERROR
core-ssh:~# hassio ha logs
Error decoding json invalid character '-' after top-level value: 2018-11-14 08:04:09 WARNING (MainThread) [homeassistant.core] Unable to find service mqtt/publish
2018-11-14 08:04:09 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 354, in _async_add_entity
await entity.async_added_to_hass()
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/mqtt.py", line 177, in async_added_to_hass
message_received, self._qos)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 306, in async_subscribe
topic, msg_callback, qos, encoding)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 688, in async_subscribe
await self._async_perform_subscription(topic, qos)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 723, in _async_perform_subscription
_raise_on_error(result)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 808, in _raise_on_error
'Error talking to MQTT: {}'.format(mqtt.error_string(result_code)))
homeassistant.exceptions.HomeAssistantError: Error talking to MQTT: The client is not currently connected.
2018-11-14 08:04:09 INFO (SyncWorker_1) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/discovery/v1/apis/calendar/v3/rest
2018-11-14 08:04:09 INFO (SyncWorker_7) [googleapiclient.discovery] URL being requested: GET https://www.googleapis.com/discovery/v1/apis/calendar/v3/rest
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/binary_sensor/mqtt.py", line 166, in async_added_to_hass
self.hass, self._state_topic, state_message_received, self._qos)
Config directory: /config
Could not get remote info for https://raw.githubusercontent.com/custom-cards/information/master/repos.json
Could not get remote info for https://raw.githubusercontent.com/kuuji/button-card/master/tracker.json
Could not get remote info for https://raw.githubusercontent.com/kalkih/mini-graph-card/master/tracker.json
Could not get remote info for https://raw.githubusercontent.com/custom-components/information/master/repos.json
2018-11-14 08:08:23 WARNING (MainThread) [homeassistant.core] Unable to find service mqtt/publish
2018-11-14 08:08:23 INFO (SyncWorker_3) [pychromecast] Querying device status
2018-11-14 08:08:23 INFO (SyncWorker_5) [pychromecast] Querying device status
2018-11-14 08:08:23 INFO (SyncWorker_0) [pychromecast] Querying device status
2018-11-14 08:08:23 INFO (SyncWorker_9) [pychromecast] Querying device status
2018-11-14 08:08:23 INFO (SyncWorker_2) [pychromecast] Querying device status
2018-11-14 08:08:23 INFO (SyncWorker_8) [pychromecast] Querying device status
2018-11-14 08:08:23 INFO (SyncWorker_6) [pychromecast] Querying device status
2018-11-14 08:08:23 INFO (SyncWorker_7) [pychromecast] Querying device status
2018-11-14 08:08:23 INFO (SyncWorker_1) [pychromecast] Querying device status
2018-11-14 08:08:23 INFO (SyncWorker_4) [pychromecast] Querying device status
core-ssh:~#
So itās not a power failure issue but a restart Home Assistant issue? The very first error seems to be MQTTā¦ what does that configuration look like?
Are you using the new integration? New version 4 of the addon? Are you using discovery? Config yaml entries for MQTT?
Hereās my MQTT config (offboard). Nothin too complex there?
mqtt:
broker: <ipofmynas> #core-mosquitto
client_id: hassio_nuc
birth_message:
topic: 'hassio/status'
payload: 'online'
will_message:
payload: 'offline'
My HA and MQTT instances are on different platforms. I found this way more reliable.
Hi @fversteegen, can you say a bit more about the steps between the Portainer install and hass.io install? For me, there is a little āand then a miracle appearsā step here. Thanks!
What step?
Did you click the link?
I installed Portainer and then it says āYouāll just need to access the port 9000 of the Docker engine where portainer is running using your browser.ā
But what is the URL here?
The URL is whatever the URL is of the box itās running on.
If you access HA on 192.168.1.100:8123 then portainer is 192.168.1.100:9000
I find this fairly well stated. You installed portainer. What machine did you install portainer on? Youāre probably connected via ssh? What IP is it?
