0.84.6 (Beta) HassOS image is now available for download for the Intel NUC platform. Testing today.
Any luck? I tried with no success. Freezes at the autoloader menu on first boot. Maybe Iâm missing something
Sadly, me too.
Anyone know of these steps are still required?
Installation
Currently there is no shiny installation method. Checklist:
Boot PC to live-environment using PXE or USB
Copy or download the hassos image into your live environment
zcat the image to local harddisk
Reboot
Here I was hoping I could just use etcher with the mssd and install back into the device and boot.
Apologies for the late reply. Did you manage to install Hass in Docker?
What I did in the step you are in now (guessing) is I didnât install hass.io through Portainer, but I installed it by sshâing into the host and running the following command:
docker run -d --name=âhome-assistantâ -v /PATH_TO_YOUR_CONFIG:/config -v /etc/localtime:/etc/localtime:ro --net=host homeassistant/home-assistant
After a while you will see homeassistant popping up in Portainer after which you can configure things like config directory and mounts easily through the Portainer interface (through editing the container and redeploying it)
The challenge starts if you want to leverage USB devices as after every reboot the name of the USB devices changes. You can overcome this by creating udev rules which essentially bind an usb device to a specific port based on serial number and/or manufacturer
No worries because you canât install hassio through Portainer.
Why do so many people have problems with this? My zwave stick never changes dev names on reboot.
Do you have 1 usb device attached or multiple ones? The issue only pops up if you have more than 1 usb device installed.
I only have one zwave USB stick.
Everything else is over the network
That then explains why you donât have the issue
The naming of USB devices (or specifically their mount points) determines on the order through which they are discovered after boot. So if you do not use UDEV it is a bit of a gamble whether your usb devices gets mounted to /dev/ttyUSB0 or to /devices/ttyUSB1
Just to let
Hi Frank, thanks for continuing to help! I now have access to Portainer on the NUC now and I can use your terminal command to install hass.io. However, what do I put in as /PATH_TO_YOUR_CONFIG?
I am on the NUC itself, so not SSHâing from another computer.
Thatâs the nice part: you decide it can be any path in the container or a path inside the host (donât forget to make it available inside Portainer!)
My suggestion is to go for the simple â/configâ option and to install the hass.io samba plugin later. If you do that you can always approach your config directory through a samba client.
Pick a place on the host OS that you want to store your configurations.
But, you guys arenât installing HASSIO if you are running docker run
. You are installing HOME ASSISTANT
hassio isnât installed with the normal docker run commands. there are no addons with the normal home assistant docker image, which you have supplied the instructions for.
Are you sure? I am pretty sure I completed those steps (though it has been a while ago) and my installation looks like belowâŚ
100% without a doubt, the homeassistant/home-assistant
image, is whole heartedly HOME ASSISTANT only, it is NOT hassio.
This command is for regular home assistant only.
Just look at the image it was pulled from in portainer.
Aha! Then I must have used: https://github.com/home-assistant/hassio-build/tree/master/install
Given my confused attempts with Docker and the fact that I only need the NUC for Hass.io anyway, I thought it might be somewhat easier to just use the new NUC Hass.io image and do exactly what I did on the Raspberry Pi.
So I downloaded the NUC image, flashed it onto a USB stick, put the stick into a NUC with no preexisting partition. However, I get stuck at the very beginning when this menu shows up and none of the options seem to do anything.
Can anybody guide me towards the next steps?
On the Raspberry Pi, this worked without a problem, but the NUC seems to be a different animal.
