Yep.
I think the NUC image is bugged right now, and is in Beta
Hey there. Check this thread. At the moment, you need to use DD or ZCat under Linux live to image the SSD on the NUC as there is no auto installer. It took me hours to work it out with the assistance of @BerryClam but once sorted, less than 5 minutes to get it working. Running sweet with 0.85.1 with 2% CPU.
https://community.home-assistant.io/t/hassos-on-nuc/90913/10
P.S Bluetooth is not working at least on my DN2820FYKH (7260).
I’m a dumb ass! Conversation with @BerryClam was private. Here is the gist of it.
gunzip -c /media/sdc1/hassos_intel-nuc-2.5.img.gz | dd of=/dev/sda bs=4M conv=fsync
@BerryClam used the following command:
gunzip -c /home/ubuntu/Downloads/hassos_intel-nuc-2.5.img.gz | sudo dd of=/dev/sda
as he had downloaded the GZ using a live Ubuntu install instead. Both methods work.
The dd command images the SSD in full with the GZ file. I made a video while I did the process but at the moment it has no sound. Happy to share if that will help.
Thanks for this! How long did your installation take? Mine has been running for an hour now… Stuck at “wlp58s0: link is not ready”…
That seems to be the network connection (wired). In Ubuntu, the network connection works fine only after the restart after the above command, it hangs…
Yep, mine said that too as I had no network connection. Moved NUC to wired network, booted up and then remote in to that location with ip:8123
Hmm, the NUC is connected via ethernet cable which works find as tested in the Ubuntu installation. Strange…
@sapnho So it doesn’t appear on your router? Is the WiFi card in your NUC currently supported? https://github.com/home-assistant/hassos/blob/dev/Documentation/boards/nuc.md
Do you think I could just use etcher to flash the image to the drive and then reinstall the mssd back into the nuc and boot?
The HDMI on my nuc are kaput so need to do a headless install also.
Will let you know in a few days. Still waiting on my mssd USB adaptor to arrive. But sounds like it should
thankyou for this video i was easily able to install hass.io to my nuc i5 d54250WYK and following the guide above was able to get my aeotec zwave gen5 stick working and samba/everything else
upgraded from a pi3b+ this nuc really blows the pi out of the water, it reboots so quick, snapshots are within a minute and zwave seems much more responsive.
just a shame that there is no GPIO as thats the only feature im missing so will have make a tasmota relay to control my alarm siren as before it was attached to the gpio on the pi but thats no problem.
thanks once again.
Are there any user input prompts onces the hard has the image in it and it boots?
I am assuming it is just like the pi install where you just plug on, turn on, wait and then access it from a webpage.
