Ok, now I understand.
I would like to be able to use your solution, but I would need some indications.
Could you explain to me generically, what would be the steps? I don’t need you to explain very detailed, but some help wouldn’t hurt me.
Do you already have mqtt?
In hassio?? Yes, of course
Then what doesn’t work? You just need to enter those 2 commands and create the config file?
t is done!
I have achieved it!
But I am found something that does not work properly.
I have 3 partitions. And don’t set the states correctly, look at this: does it happen to you anyway?
I build one of the partitions:
published alarm status disarmed on partition 0
published alarm status disarmed on partition 1
published alarm status disarmed on partition 2
received change state command ARM_HOME on topic riscopanel / alarm / 2 / set in partition 2
changed state to armed_home on partiton 2
published alarm status armed_home on partition 0
However, it is partition 0 that is armed, when it should be 2.
The same happens to me with 1. Only 0 works correctly.
For what is this?
thanks
Great you did it
But can’t help, I only have one partition …, Works good here
Maybe you can try to setup the mqtt alarm control panel manually to send the payloads?
for information
PR is approved, for info , this will be ready for 115
Thnx onfreund!! Appreciated
