I’ve worked it out, I needed to update the strings in the transforms section for home assistant of the config.js
Just one question, should I be getting a log file in the mqtt/log folder? I don’t have anything in that folder
Hi all,
Is there a instruction available somewhere for a real dummy to get the Risco alarm integrated in Home Assistant?
Preferably a step-by-step guide.
Thanks.
For a dummy , this is the easiest one to setup
martingrayson/hassio-addons
Thanks Fabio, but I really don’t know what to do with the JSON file or what is needed for this.
everything is explained here:
ah, sorry, my bad. I didn’t scroll all the way down.
Looks very straight forward. Thank you!
Hi Fabio,
I’m trying to adapt this Plugin for Hassio, but I can’t.
You can help?
thanks
i dont use that one
Why not? It seems to work a little better. It’s possible?
and could you not help me convert it addons for hassIO?
yes, indeed it works better according to readme, but its not available a a docker/addon , so you need to do it manually
i run HassOS, so thats not an option for me i think
so i use Luca Version, and it works quite good for me, the only “issue” is the small delay when you arm
and sometimes i have to restart the docker one a week, since it doesnt update anymore
restarting once a week is something heavy … Besides, I don’t like the idea of scrapping the web. well, I will continue investigating, to be able to convert the addon to hassio.
thank you
Why not use Luca version? I run in it Portainer add-on
You can also use ha-dockermon to restart Dockers on scheduled base, like every night
But I already created an issue/question on that GitHub page you posted earlier about instructions to install as a docker… So waiting also for feedback… An add-on would be even nicer…
But then you need to use the Martin version, that’s a Haddon, allthough not that stable
Well, for nothing special.
If there was no other possible solution, I would use it, but seeing the option mentioned above, I would like to be able to use it.
I have written too.
Thank you very much, hopefully news.
I have seen that you have managed to operate the new add-ons that I mentioned. Would you know how to make it work in Hassio? Thank you
i just followed instructions? where are you stuck ? it isnt an add-on, you need to run it manually on your linux system
but with Hassio?
Hassio no can install npm
indeed, not possible with hassio
i also have HassOS, not possible there
so setup a linux system create the project there, create a docker image if all is working good
then you can load that docker image in the “portainer” addon if all is working
mmm, I understand …
But I don’t know how to create a Docker image myself and port it to Hassio.
On the other hand, why is it not possible in Hassio?
Can’t create a Hassio plugin, from the code?
dont create a docker image yet, just start using/testing that nodejs script, like in instructions
use ubuntu or something like that… if all is working, then create a docker
example instructios here; https://nodejs.org/de/docs/guides/nodejs-docker-webapp/
plugin/addon is not possible,… i dont have code experience to make an addon, maybe someone else can… so i created the docker manally and just load it with portainer addon, so its perfect for me
