MyQ down again
Looks like MyQ integration is down again. Below is the error. Tried to remove and re-add the integration and still the same error. Anyone else have similar issues?
Logger: homeassistant.components.myq.config_flow
Source: components/myq/config_flow.py:30
Integration: MyQ ([documentation](https://www.home-assistant.io/integrations/myq), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+myq%22))
First occurred: 7:08:47 PM (1 occurrences)
Last logged: 7:08:47 PM
Unexpected exception
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/myq/config_flow.py", line 50, in async_step_user info = await validate_input(self.hass, user_input) File "/usr/src/homeassistant/homeassistant/components/myq/config_flow.py", line 30, in validate_input await pymyq.login(data[CONF_USERNAME], data[CONF_PASSWORD], websession) File "/usr/local/lib/python3.8/site-packages/pymyq/api.py", line 259, in login await api.authenticate(username, password, False) File "/usr/local/lib/python3.8/site-packages/pymyq/api.py", line 170, in authenticate auth_resp = await self.request( File "/usr/local/lib/python3.8/site-packages/pymyq/api.py", line 151, in request return await self._send_request( File "/usr/local/lib/python3.8/site-packages/pymyq/api.py", line 114, in _send_request message = f"Error requesting data from {url}: {data.get('description', str(err))}" UnboundLocalError: local variable 'err' referenced before assignment
3 posts were merged into an existing topic: MyQ garage opener hub integration not working
