I just started migrating from Smartthings + Webcore to Home Assistant OS on a NUC. Absolute noob here. The primary reason for this switch is because all my automation through Smartthings is tied to the cloud. I wanted HA to provide me more in-house direct control of my home automation system with less cloud dependency.
That said, I am trying out the Nabu Casa cloud service just for Alexa integration. I already setup my system with DuckDNS for remote access, so don’t need that. Here is my question/problem:
Nabu Casa seems to have gone down. Their login portal is giving me a 504. But here is the big problem, the lack of Nabu Casa seems to have brought Home Assistant OS to its knees. It will not complete the load of HA. Barely anything is running. I keep getting the: “Home Assistant is starting, not everything will be available until it is finished.”
Obviously, my big issue with this is that this is the kind of situation I’m trying to move away from. I would expect the Nabu Casa integration to fail and the system to just move on. I should be able to use the rest of my system. As it is, that integration absolutely impairs the stability of my system. I rather loose Alexa integration and keep everything else.
System Health:
System Health
Home Assistant Core Integration
version: 0.118.0
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.6
os_name: Linux
os_version: 5.4.63
arch: x86_64
timezone: America/Chicago
Hass.io
host_os: HassOS 5.5
update_channel: stable
supervisor_version: 2020.11.0
docker_version: 19.03.12
disk_total: 468.8 GB
disk_used: 2.7 GB
healthy: true
supported: true
board: intel-nuc
supervisor_api: ok
version_api: ok
installed_addons: Visual Studio Code (2.8.2), File editor (5.2.0), Duck DNS (1.12.4), Terminal & SSH (8.9.1)
Lovelace
dashboards: 2
mode: auto-gen
resources: 0
Here is my home-assistant.log:
2020-11-25 11:34:21 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=40 from 2020-11-25 17:23:56.455984)
2020-11-25 11:34:31 WARNING (MainThread) [homeassistant.setup] Setup of cloud is taking over 10 seconds.
2020-11-25 11:34:52 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:35:21 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: cloud
2020-11-25 11:35:32 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:36:10 ERROR (MainThread) [hass_nabucasa.iot] Unexpected error
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 445, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 440, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.8/http/client.py", line 1347, in getresponse
response.begin()
File "/usr/local/lib/python3.8/http/client.py", line 307, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.8/http/client.py", line 268, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.8/socket.py", line 669, in readinto
return self._sock.recv_into(b)
File "/usr/local/lib/python3.8/ssl.py", line 1241, in recv_into
return self.read(nbytes, buffer)
File "/usr/local/lib/python3.8/ssl.py", line 1099, in read
return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
File "/usr/local/lib/python3.8/site-packages/botocore/httpsession.py", line 254, in send
urllib_response = conn.urlopen(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 506, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.8/site-packages/urllib3/packages/six.py", line 735, in reraise
raise value
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 447, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 336, in _raise_timeout
raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: AWSHTTPSConnectionPool(host='cognito-idp.us-east-1.amazonaws.com', port=443): Read timed out. (read timeout=60)
File "/usr/local/lib/python3.8/site-packages/hass_nabucasa/iot_base.py", line 108, in connect
await self._handle_connection()
File "/usr/local/lib/python3.8/site-packages/hass_nabucasa/iot_base.py", line 147, in _handle_connection
await self.cloud.auth.async_check_token()
File "/usr/local/lib/python3.8/site-packages/hass_nabucasa/auth.py", line 172, in async_check_token
await self._async_renew_access_token()
File "/usr/local/lib/python3.8/site-packages/hass_nabucasa/auth.py", line 199, in _async_renew_access_token
await self.cloud.run_executor(cognito.renew_access_token)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/site-packages/pycognito/__init__.py", line 617, in renew_access_token
refresh_response = self.client.initiate_auth(
File "/usr/local/lib/python3.8/site-packages/botocore/client.py", line 357, in _api_call
return self._make_api_call(operation_name, kwargs)
File "/usr/local/lib/python3.8/site-packages/botocore/client.py", line 647, in _make_api_call
http, parsed_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/botocore/client.py", line 667, in _make_request
return self._endpoint.make_request(operation_model, request_dict)
File "/usr/local/lib/python3.8/site-packages/botocore/endpoint.py", line 102, in make_request
return self._send_request(request_dict, operation_model)
File "/usr/local/lib/python3.8/site-packages/botocore/endpoint.py", line 136, in _send_request
while self._needs_retry(attempts, operation_model, request_dict,
File "/usr/local/lib/python3.8/site-packages/botocore/endpoint.py", line 228, in _needs_retry
responses = self._event_emitter.emit(
File "/usr/local/lib/python3.8/site-packages/botocore/hooks.py", line 356, in emit
return self._emitter.emit(aliased_event_name, **kwargs)
File "/usr/local/lib/python3.8/site-packages/botocore/hooks.py", line 228, in emit
return self._emit(event_name, kwargs)
File "/usr/local/lib/python3.8/site-packages/botocore/hooks.py", line 211, in _emit
response = handler(**kwargs)
File "/usr/local/lib/python3.8/site-packages/botocore/retryhandler.py", line 183, in __call__
if self._checker(attempts, response, caught_exception):
File "/usr/local/lib/python3.8/site-packages/botocore/retryhandler.py", line 250, in __call__
should_retry = self._should_retry(attempt_number, response,
File "/usr/local/lib/python3.8/site-packages/botocore/retryhandler.py", line 277, in _should_retry
return self._checker(attempt_number, response, caught_exception)
File "/usr/local/lib/python3.8/site-packages/botocore/retryhandler.py", line 316, in __call__
checker_response = checker(attempt_number, response,
File "/usr/local/lib/python3.8/site-packages/botocore/retryhandler.py", line 222, in __call__
return self._check_caught_exception(
File "/usr/local/lib/python3.8/site-packages/botocore/retryhandler.py", line 359, in _check_caught_exception
raise caught_exception
File "/usr/local/lib/python3.8/site-packages/botocore/endpoint.py", line 200, in _do_get_response
http_response = self._send(request)
File "/usr/local/lib/python3.8/site-packages/botocore/endpoint.py", line 244, in _send
return self.http_session.send(request)
File "/usr/local/lib/python3.8/site-packages/botocore/httpsession.py", line 289, in send
raise ReadTimeoutError(endpoint_url=request.url, error=e)
botocore.exceptions.ReadTimeoutError: Read timeout on endpoint URL: "https://cognito-idp.us-east-1.amazonaws.com/"
2020-11-25 11:36:12 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:36:21 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: cloud
2020-11-25 11:36:52 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:37:09 WARNING (MainThread) [hass_nabucasa.iot] Cannot connect because unable to refresh token: Gateway Timeout
2020-11-25 11:37:21 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: cloud
2020-11-25 11:37:32 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:38:12 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:38:21 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: cloud
2020-11-25 11:38:52 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:39:19 WARNING (MainThread) [hass_nabucasa.iot] Cannot connect because unable to refresh token: Gateway Timeout
2020-11-25 11:39:21 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: cloud
2020-11-25 11:39:22 ERROR (MainThread) [homeassistant.setup] Setup of cloud is taking longer than 300 seconds. Startup will proceed without waiting any longer
2020-11-25 11:39:32 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:40:12 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:40:29 WARNING (MainThread) [hass_nabucasa.iot] Cannot connect because unable to refresh token: Gateway Timeout
2020-11-25 11:40:52 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:41:32 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:41:57 WARNING (MainThread) [hass_nabucasa.iot] Cannot connect because unable to refresh token: Gateway Timeout
2020-11-25 11:42:12 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:42:52 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:43:32 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:44:12 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:44:43 WARNING (MainThread) [hass_nabucasa.iot] Cannot connect because unable to refresh token: Gateway Timeout
2020-11-25 11:44:52 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:45:32 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:46:12 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:46:52 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:47:13 WARNING (MainThread) [hass_nabucasa.iot] Cannot connect because unable to refresh token: Gateway Timeout
2020-11-25 11:47:32 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:48:12 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:48:52 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:49:32 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:50:12 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:50:35 WARNING (MainThread) [hass_nabucasa.iot] Cannot connect because unable to refresh token: Gateway Timeout
2020-11-25 11:50:52 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:51:32 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:52:12 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:52:52 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:53:32 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:54:12 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:54:52 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:55:32 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:56:12 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2020-11-25 11:56:52 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
