Nabu.casa down?
I can not access my HA through Nabu.Casa. My HA is up cause I can access it on my VPN.
Anyone else having this problem?
It’s the same here
Wonder if it was something I did. I was playing around with my firewall last night. Everything was fine up until mid morning today.
working here,
but what i notice earlier, if you restart your HA, then in my case it didnt reconnect automaticly…
so went back to : https://remote.nabucasa.com/, and did a reconnect
or maybe you can launch the service from HA to do a connect
Yes a restart of HA fixed it. I could see in the logs saying there was a SSL error connecting to Nabucasa.
You’re right !!
It works
Thank you
anyone having this problem today?
not me, connected here
Working for me :slight_smile:
Working fine
I have problems today. Getting notifications, but cannot connect.
  • and i am 2500 miles from home
I have a vpn setup at home just for that reason. That way when I’m on the other side of the world I can still login to my network.
I was able to turn on port forwarding remote and get in to do a HA restart… Nabu connection is back up
Have no connection now
I am around 2000 km from home too.
The problem was with my HA server. Once I rebooted it, everything started to work agai
for me also now nabu casa down
while in overview i still see my account as connected state:
Cloud connection status
Connected
calling the service manually to connect doesnt help either
cloud.remote_connect
if i go to this site :
then i have this error :
Connect to your Home Assistant instance remotely.
Connection failed: No response from instance
Working all fine here without issue
yes, i restarted now HA
now its connected again, not sure what cause was
Same thing here. Father restarted and everything is fine. Do not know why pi was down
