I have setup cron jobs on all my CT’s in Proxmox and server that pings https://healthchecks.io that in turn lets me know if one of them goes down.Its a nice piece on mind.
I’m currently seeing this when I go to my ui.nabu.casa URL where I would typically be able to log in:
“Error: Something went wrong.” Not a very descriptive error. Correct – but not very descriptive.
I cant access mine and my settings says that its still not even ready yet since updating till .94
Problem seems to be just with the cloud login, I guess…all my cloud webhooks are still working, and I can see that the connection that HA makes out to nabu casa is succeeded in my logs.
And since I’m trying to login for the first time, it simply refuses to let me. It just says “Unable to reach the HA cloud”
it looks like it’s serving nothing on 443, openssl s_client shows no certificate being exchanged. httpd probably pooped its pants. maybe ssl cert autorenewal failed?
EDIT: Found the root cause, my DNS resolver crashed. So the issue was not related to Nabu Casa
I also am having this problem. At first it was stuck at “Connecting”. Then I logged out on Home Assistant and when I now enter my credentials it says “Server cannot be reached”.
Figured out my issue. My http configuration, because I use a NGINX reverse proxy on the same machine as my HA instance, was as follows:
http:
base_url: !secret base_url
use_x_forwarded_for: true
trusted_proxies:
- 127.0.0.1
For whatever reason, I never thought to check the configuration/Home Assistant Cloud page in HA, which said that 127.0.0.1 is no longer supported for trusted_proxies when it comes to nabu casa remote control.
Everything seemed to work after I switched the reverse proxy to the machine’s real IP address.
This change was mentioned in the release notes, but not as a breaking change, so I never thought about it:
- Check cloud trusted proxies (@balloob - #24395) (cloud docs) (http docs)
lots of issues here also, been working good for a long while, now i norticed it was offline again
calling the service within HA doesnt work, i get this error
so to make it up an running, i need to restart HA
2019-06-14 08:29:27 ERROR (MainThread) [hass_nabucasa.remote] Can't handle request-connection without backend
2019-06-14 08:29:27 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.140064150741064]
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 121, in handle_call_service
connection.context(msg))
File "/usr/src/homeassistant/homeassistant/core.py", line 1150, in async_call
self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1172, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 367, in admin_handler
await hass.async_add_job(service_func, call)
File "/usr/src/homeassistant/homeassistant/components/cloud/__init__.py", line 184, in _service_handler
await cloud.remote.connect()
File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/remote.py", line 250, in connect
raise RemoteNotConnected()
hass_nabucasa.remote.RemoteNotConnected
Nabu is down?
Olá! My nabu integration its activated but not connecting to my google home!!
After delete my account in google assistant and added it again, i am getting the error: “Its not possible to update your configuration. Verify you connection.”
Its down for me also. Was working yesterday.
Edit:
I updated Hassio yesterday. Just now found that the switch for Remote Control under Home Assistant Cloud was off. Not sure why. I should have checked that before posting here.
Same here.
504 Gateway Time-out
Identified - Due to an outage at Amazon Web Services, users are currently unable to login to Home Assistant Cloud or receive messages via Google and Alexa. Amazon is working on fixing the situation.
https://status.aws.amazon.com/
Nov 25, 07:59 PST
mine still works
Down for me amazon and Google not working
My cloud seems to be down too.
Logger: homeassistant.setup
Source: /usr/local/lib/python3.8/asyncio/events.py:81
First occurred: 18:42:05 (1 occurrences)
Last logged: 18:42:05
Hello all
I am a subscriber to HA Cloud via Nabucasa to access HA when I’m away and to control HA via Alexa
now i cannot access HA from away nor can i use alexa.
when i try to access the nabucasa UI i get “Connection failed: No response from instance”
Why? i’m paid up (checked) is nabucasa down again?
