+1 i also would love to see that feature. Have two different HA instances to manage…
+1 as well. I’m going to have two instance running for a year, and need to be able to manage both of them as I migrate systems over to the new one.
What is the status of this ? I have three instances. Home, yacht and cabin and would like to access all of them through my single nabu casa profile
From the Nabu Casa FAQ: Can I use a single account for multiple Home Assistant installations?
“This is not possible. It would require large changes to how the service works and our current focus is on evaluating and improving the stability and scale of a single instance per subscription.”
I spoke to Nabu Casa in August 23 as I was automating 300 houses and required this functionality in order to manage the cloud for my clients. They said no so I had to use OpenHab instead as they offer cloud for free. I did not mind paying for HA cloud I just could not expect each client to sign up, pay and manage their own cloud service along with paying my company separately for other services. It would confuse them and be a nightmare for my company to manage.
This being said I doubt this functionality will be added any time soon as even with the potential of hundreds more subscriptions and a lot more in future I received a no.
It’s frustrating as I prefer HA but commercially I only offer OpenHab as account management is a deal breaker for me.
Agreed. The fact that this is not a BASIC function of HA Cloud is ludicrous. Yes, it could result in a major refactoring of code. Yes, it’s a big deal. Should it take (now, almost THREE) YEARS to do this? Absolutely not!
Even Vera can manage this. I was ready to pull the trigger and move to HA and Nabu Casa but now I’m not sure.
I got a home assistant yellow and want to play around with it before using it for my main instance. I wouldn’t even mind setting up multiple accounts and paying for each of them, but the mobile app doesn’t seem to support multiple accounts. This functionality would ~not~ require any refactoring on the cloud side.
Hi there is a way to add multiple instances to the app. In the app you have to go to settings->Companion App-> then add a server here , you can add here multiple instances .Switching is a bit clunky because you always have to go to the settings and then select the instance then activate the instance you want to currently use. For testing your new instance that should suffice.
I currently manage 2 instances using Nabu Casa and all works well. I had to use two different email addresses to set them up. Switching in the mobile app is not clean but it does work. I have no issue paying the monthly fee for both accounts. However, I now want to add a third account. Again, no issue paying for it. However, it will now require a 3rd email address to set it up. I am not in the habit of using “burner” email accounts. Any suggestions on how to to be able to manage all 3 accounts with a single email address?
If you are using Gmail, you can just use “+” addressing to the end of your Gmail address ([email protected]) Nabu Casa treats them as separate account ids but they still come back to your main email address.
In at least the Android App you can use a 3 finger swipe to switch between accounts
Is this anywhere on the roadmap? I’d like an update on this feature and if it’s being worked on , or not. I havent seem much clamouring in here so I figured I would add.
Would love to be able to have two (or more) instances of Home Assistant in my NabuCasa. It would be even more great to also manage them centrally but run local.
Maybe a NabuCasa Pro service? I’m not agains paying more for more functionality…
Update!
I poked them this weeks about this feature and this was their answer
“Hi Joseph,
It is on the roadmap but not before several other features which are currently being worked on are in place. I do not have an ETA to provide for managing multiple servers under one Nabu Casa account but it is on the list of things to do!
Regards,
Ashton
Nabu Casa Support
1/1/2025”
I found this thread, eagarly hoping there was a higher tier of subscription for say
1 instance
1-9 instances
10+
etc
Like others here i have many HA builds to look after, all in one place would be amazing.
6 years… really…?
not being able to control multiple homes with one nabu casa cloud is the only reason i’m not buying it ![]()
If you could just use the same email for multiple accounts it would be better. (at least it was this way when I last looked into it)
I can’t bring myself to do two accounts with two separate emails. I have enough to keep up with already…don’t make me maintain another email for a second account. Using account numbers or something other than email to keep track of accounts is certainly doable.
