Hi Guys,
What’s the best way to name your multiple Lights in one room for HA & google Home ?
For example I have the master Bedroom : 1x Main light and two separate bedside Lamps. The main light is the Sonoff T3 and the two Bedside Lamps have Sonoff Basic connected separately.
Some suggestions in the naming of these light’s so that google home does not get confused when you give an instruction on the Master bedroom lights.
Like to see what your naming of lights that does not cause confusion.
Ah well I moved to amazon echo a while back. Can’t remember if i had any issues before but don’t think so. For echo no problem with individual names nor any issue with groups. I like to use groups as aliases as well so when the wife says something like “alexa turn on the lamp or alexa turn off the bedside lamp” instead of “alexa turn on the master bedroom table lamp” is works for her.
