just like to conform, for me, it is not working with botvac d3.
I take a look at the API-Documentation and found a way to get my D3 working with the existing Component, after editing the robot.py
Just read a little bit in the API-Documentation.
Heres my Code. Just had to adopt some JSON-Calls
import requests
import hmac
import time
import os.path
# Disable warning due to SubjectAltNameWarning in certificate
requests.packages.urllib3.disable_warnings()
class Robot:
"""Data and methods for interacting with a Neato Botvac Connected vacuum robot"""
def __init__(self, serial, secret, name=''):
Initialize robot
:param serial: Robot serial
:param secret: Robot secret
:param name: Name of robot (optional)
self.name = name
self.serial = serial
self.secret = secret
self._url = 'https://nucleo.neatocloud.com/vendors/neato/robots/{}/messages'.format(self.serial)
self._headers = {'Accept': 'application/vnd.neato.nucleo.v1'}
def __str__(self):
return "Name: %s, Serial: %s, Secret: %s" % (self.name, self.serial, self.secret)
def _message(self, json):
Sends message to robot with data from parameter 'json'
:param json: dict containing data to send
:return: server response
cert_path = os.path.join(os.path.dirname(__file__), 'cert', 'neatocloud.com.crt')
response = requests.post(self._url,
json=json,
verify=cert_path,
auth=Auth(self.serial, self.secret),
headers=self._headers)
response.raise_for_status()
return response
def start_cleaning(self):
json = {'reqId': "1",
'cmd': "startCleaning",
'params': {
'category': 2,
'navigationMode': 2}
return self._message(json)
def pause_cleaning(self):
return self._message({'reqId': "77", 'cmd': "pauseCleaning"})
def resume_cleaning(self):
return self._message({'reqId': "77", 'cmd': "resumeCleaning"})
def stop_cleaning(self):
return self._message({'reqId': "77", 'cmd': "stopCleaning"})
def send_to_base(self):
return self._message({'reqId': "77", 'cmd': "sendToBase"})
def get_robot_state(self):
return self._message({'reqId': "1", 'cmd': "getRobotState"})
def enable_schedule(self):
return self._message({'reqId': "1", 'cmd': "enableSchedule"})
def disable_schedule(self):
return self._message({'reqId': "1", 'cmd': "disableSchedule"})
def get_schedule(self):
return self._message({'reqId': "1", 'cmd': "getSchedule"})
@property
def schedule_enabled(self):
return self.get_robot_state().json()['details']['isScheduleEnabled']
@schedule_enabled.setter
def schedule_enabled(self, enable):
if enable:
self.enable_schedule()
else:
self.disable_schedule()
@property
def state(self):
class Auth(requests.auth.AuthBase):
"""Create headers for request authentication"""
def __init__(self, serial, secret):
def __call__(self, request):
date = time.strftime('%a, %d %h %Y %H:%M:%S', time.gmtime()) + ' GMT'
signing = hmac.new(key=self.secret.encode('utf8'),
msg='\n'.join([self.serial.lower(), date, request.body.decode('utf8')]).encode('utf8'),
digestmod='sha256')
request.headers['Date'] = date
request.headers['Authorization'] = "NEATOAPP " + signing.hexdigest()
return request
Any Chance to implement this to the existing Component? Or can someone with an older connected Model if this also works?
BR
Lukas
