Good afternoon,
My name is Richard, living in the Netherlands.
I have been working with Home Assistant for a few months now. In itself, I’m doing fine with installing the usual integrations.
But now the following: I bought a smart TV lift, and I would like to integrate it so that I can create an automation when the TV is turned on and the lift rises. This concerns this model: MyWall TV Lift Medium HP63-1 - Beugels en Meer
With the normal Tuya integration, the device is recognized, after the name it says (unsupported). Device was added without entities. So this was not an option. I continued looking for a solution and then came across the local-tuya integration.
The local-tuya integration has been installed. I have carefully followed the documentation instructions. Adding the device goes well.
Auto configure does not work:
Then I continued with the manual configuration. Chosen for the ‘cover’ entity, as in my opinion it most closely matches the type of device.
I can’t go any further from here. I have tried many combinations and things, but without success. However, at one point there was a response that the lift was going up, but that suddenly stopped working.
What else I was able to find on the tuya API explorer site (get instruction set) is the following:
“result”: {
“category”: “zndsj”,
“functions”: [
“code”: “move”,
“desc”: “{"range":["move_up","move_down","move_left","move_right","move_default","cancel"]}”,
“name”: “运行控制”,
“type”: “Enum”,
“values”: “{"range":["move_up","move_down","move_left","move_right","move_default","cancel"]}”
“code”: “memory”,
“desc”: “{"range":["mem1","mem2","mem3","recall1","recall2","recall3","cancel"]}”,
“name”: “位置记忆”,
“type”: “Enum”,
“values”: “{"range":["mem1","mem2","mem3","recall1","recall2","recall3","cancel"]}”
“status”: [
“code”: “move”,
“name”: “运行控制”,
“type”: “Enum”,
“code”: “model_no”,
“name”: “型号”,
“type”: “String”,
“values”: “{"maxlen":255}”
“code”: “memory”,
“name”: “位置记忆”,
“type”: “Enum”,
“code”: “fault_code_report”,
“name”: “故障码上报”,
“type”: “Bitmap”,
“values”: “{"label":["fault_code_1","fault_code_2"],"maxlen":2}”
“success”: true,
“t”: 1707395295815,
“tid”: “8874b9f2c67d11eea1957edaaa357452”
If anyone could help me with this, that would be great! I would like to hear from you!
Thank you
Greetings,
Richard
