I try to configure influxdb sensor with follow code added to configuration.yaml :
- platform: influxdb
host: 192.168.1.90
username: username
password: pass
queries:
- name: Moisture
value_template: '{{ (100 - float(value) / 11) | round(1)}}'
unit_of_measurement: '%'
group_function: last
where: '"time" > 0'
measurement: 'moisture'
field: level
database: plant
- name: Threshold
where: '"time" > 0'
field: threshold
database: plant
and get this error :
Unable to prepare setup for platform influxdb.sensor
Unable to set up component.
Error during setup of component influxdb
File "/usr/src/homeassistant/homeassistant/setup.py", line 229, in _async_setup_component
result = await task
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/src/homeassistant/homeassistant/components/influxdb/__init__.py", line 473, in setup
conf = config[DOMAIN]
KeyError: 'influxdb'
influxdb is on other hardware on the same local network with home assistant raspberry pi.
i`m new on HA so thanks in advance for any help.
