I’m quite new to home assistant and trying to integrate influxdb to homeassistant. Ideally I want the data shown as a time series graph, but one problem at a time.
I get an error I’ve found in two other home assistant posts, but neither were solved, and they’re somewhat old and both using influx api version 1, whilst I’m using version 2. (linked at bottom of this post)
in configuration.yaml:
sensor: !include_dir_merge_list sensors/
in sensors/influxdb.yaml
- platform: influxdb
api_version: 2
ssl: false
host: 192.168.16.156
port: 8086
organization: !secret influxdb_org
token: !secret influxdb_token
bucket: new_lab_sensors
queries_flux:
- group_function: mean
name: "Data from DB"
query: 'from(bucket: "new-lab-sensors") |> range(start: -24h) |> filter(fn: (r) => r["_measurement"] == "temperature") |> aggregateWindow(every: 5m, fn: mean, createEmpty: false) |> yield(name: "mean")'
Log Details
Logger: homeassistant.setup
Source: components/influxdb/__init__.py:483
First occurred: 12:27:55 (1 occurrences)
Last logged: 12:27:55
Error during setup of component influxdb
File "/usr/src/homeassistant/homeassistant/setup.py", line 288, in _async_setup_component
result = await task
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/influxdb/__init__.py", line 483, in setup
conf = config[DOMAIN]
KeyError: 'influxdb'
Other posts:
