Need help with Zwave Association and RF9601 & RF9617
Hi,Petro
I have a question( maybe silly) I got me a RF9601 Zwave Eaton sw and RF9617 addon sw to use for 3way location. both of them registered in zwave js and rf9601is working fine mechanically and through the HA but RF9617 I don’t know how to pair with main one. And where I can find a Multicast in Zwave JS
Thank you in advanced
It pairs using zwave association, nothing to do with multicast.
Pulled from the RF9601 manual
Yes,sorry this is what i mean
I confuse how to do this
Read this thread
I find this info
Maybe it will be helpful for some people but still no idea what should I do with mine
Z-Wave Groups, Scenes & Associations — Vesternet
Did you read the thread linked above? I wrote on it you need to use zwavejs2mqtt to set associations, and included links to the documentation that include the screenshots for how to set them.
Yes I did and I will try to do this tonight
I install zwavejs2mqtt but didn’t play with it yet
TY
be aware that you can’t run zwavejs2mqtt and the zwavejs add-on at the same time since they can’t both access the zwave controller simultaneously.
So I have to disable JS?
Yes, this post may help as well
If by that you mean disable the zwavejs add-on then yes.
Don’t disable the zwavejs integration tho.
You could run into a problem if you installed the zwavejs add-on at the same time as installing the integration.
The supervised add-on will restart itself automatically.
