Unfortunately it does not work! I bought the sensor at aliexpress, so most probably this device is total crap! It will go into the garbage box!
Thanks for help, topic can be closed!
You might have a dud. But I have about 8 running fine and 1 arrived dead. Just file a dispute on Ali or contact the seller. They will probably help you for a replacement.
Finally I got the sensor running!
Unfortunately I cannot change the node config option! Any help regarding this?
You need to wake the PIR sensor by pushing the button inside once. Then immediately click the button in HA that sends the config option. Might take a couple of tries.
