Looks great. Experimentally works for me.
Wonder if the Neolink can be triggered by the RIP through an e-mail notification. Otherwise, this solution will drain the camera battery
Hey. Installed the addon right now.
The addon starts but it cant connect to my Argus 2. Im running neolink with the same config in a lxc Container too where it works. Is there anything im missing? Looks for me like a permission / Firewall issue inside of HA because its solving the UID but cant connect (Timeout)
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[2022-11-16T07:32:15Z INFO neolink] Neolink d75e416c96b9867875bc7252777302e8cec214ab release
[2022-11-16T07:32:20Z INFO neolink_core::bc_protocol::connection::udpconn::discover] Trying remote discovery against reolink servers
[2022-11-16T07:32:25Z ERROR neolink::rtsp] Error streaming from camera Wohnzimmer, will retry in 1s: Failed to connect to camera Wohnzimmer at UID: xxxxxxxxxxxxx on channel 0
Caused by:
0: Connection error
1: Timeout
would guess some firewall, routing, ⌠problems. add-on itself runs properly but is having problems to reach reolink servers. has nothing to do with my add-on and I am sorry but I cant helpâŚ
I seem to have the add-on config working and connecting to my Reolink camera. I have a bind of 127.0.0.1 for the config. Trying to setup a generic camera to view the link, but have no idea what ip address to use. The actual home assistant ip or 127.0.0.1 does not seem to work. Any thoughts or instruction would be appreciated
Thanks for your reply. That is exactly the setup I had initially. Does not work unfortunately (the URL times out when setting up a generic camera). Could it be something to do with using Home Assistant OS? I had neolink working separately from home assistant once upon a time, but that was not with Home Assistant OS.
the url I have tried is rtsp://192.168.xx.xx:8554/baby/subStream
my config is as follows:
bind = â0.0.0.0â
[[cameras]]
name = âbabyâ
username = âadminâ
password = xxxxxx
address = â[i.p of neolink]:9000â
stream = âsubStreamâ
A bit of progress made. I commented out the stream option and suddenly all works. Although I wanted the subStream only but at least I know its not a i.p address or network issue now.
I have had the subStream option working in the past. Not sure why it wouldnât work with this addon?
Trying to get this working but I am also struggling to get the url to work in a generic camera. Receiving the following in the Neolink logs:
Caused by:
0: Media Deserialization error
1: Parsing error
[2022-11-26T21:14:44Z ERROR neolink_core::bc_protocol::connection::udpconn] Udp read poll aborted
[2022-11-26T21:14:44Z ERROR neolink_core::bc_protocol::connection::udpconn] Udp write poll aborted
[2022-11-26T21:14:50Z INFO neolink_core::bc_protocol::connection::udpconn::discover] Trying remote discovery against reolink servers
[2022-11-26T21:14:51Z INFO neolink::rtsp] Front Porch Camera: Connecting to camera at UID: *****************
[2022-11-26T21:14:51Z INFO neolink::rtsp] Front Porch Camera: Logging in
[2022-11-26T21:14:51Z INFO neolink::rtsp] Front Porch Camera: Connected and logged in
[2022-11-26T21:14:52Z INFO neolink::rtsp] Front Porch Camera: Camera time is already set: 2022-11-26 16:14:49 -5
[2022-11-26T21:14:52Z INFO neolink::rtsp] Front Porch Camera: Camera reports firmware version v3.0.0.1045_22061301
[2022-11-26T21:14:52Z INFO neolink::rtsp] Front Porch Camera: Starting video stream Main Stream (Clear)
Receiving timeout errors when trying to setup the generic camera. I have Neolink installed using the experimental addon.
Receiving this error in the log:
Error from stream worker: Error opening stream (HTTP_NOT_FOUND, Server returned 404 Not Found) rtsp://192.168.xx.xx:8554/FrontPorchCamera
I wanted to add the address (GitHub - dm82m/hassio-addons) via the addon store repositories. Unfortunately an installation of Neolink was not possible. Could you add a step by step guide.
I can confirm that the recent update did make progress in my situation but itâs still quite unstable. I was able to setup the generic camera but it loses connection very frequently with the same âMedia Deserialization errorâ I was receiving previously.
Checking the full logs shows many âno additional packetsâ errors:
2022-12-07 22:08:38.532 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.192_***_*_***] Error from stream worker: Stream ended; no additional packets
I think I found an open issue that matches my situation as I am also using an Argus PT and running into the same problems described here:
One thing that is strange, the camera feed seems to be much more stable when accessed via the mobile app (running on a Pixel 3a) as opposed to the desktop which constantly stutters and quickly flashes a âError with media stream contentâ message. It usually then freezes completely before briefly becoming unavailable.
