I’m wondering if there’s a reason that the hvac_action attribute does not appear in my Nest thermostat climate entity in the Matter integration. All other attributes show up (cooling vs. heating mode, set temperature, actual temperature), but it’s not possible to tell what the thermostat is actually doing (is it idle or actually calling for AC, for instance).
hvac_action works fine through the Nest integration.
It’s an important feature for me. I have an on-demand water heater that functions to provide both domestic hot water and hot water for heating my house. The domestic hot water always takes priority.
I have a domestic hot water recirculating system controlled by Home Assistant, but I only run it when there’s no demand to heat the house (i.e., I don’t want to shut off the heat to my house just to heat recirculated water). Right now, I check for whether there’s heating demand (hvac_action set to “heating”) by using the Google cloud integration (which is not 100% reliable); I’d rather do it locally with the Matter integration.
I am facing the same challenge. My second floor HVAC systems is not well balanced as the only HVAC registers are in the bedrooms, but the Nest thermostat is in the hallway (where there are no registers). I installed a through-wall exhaust fan from AC Infinity, and put it on a switch using the Innovelli Blue fan switch. My intent was to trigger an automation based on the Nest HVAC Action to turn on the exhaust fan to balance the temperature upstairs. However, since my Nest is integrated via Matter, the HVAC action is not exposed, that automation is not possible. I can shift back to the Nest integration, but like many, I would prefer to move away from integrations that require the cloud.
I’d really like to know the answer to this persistent omission. Is it that Google Nest doesn’t expose this via Matter, or is the Matter integration just not picking it up? (Or is it not yet supported for any Matter thermostats?)
This is a bummer to see this. I am switching away from a Nest Learning thermostat and was considering a model of theirs that supports matter but this would be a deal breaker for me.
