It’s a very vanilla setup Tobi. I am using an RPI 3 b+. I did have just the DuckDNS addon for SSL remote access but was talked into adding the Nginx addon for internal access as I had mentioned in this forum that having an internal url seemed silly if you had remote access. So what did that buy me - I can now access my HASS instance internally without using my external URL. Anyway, about a month ago. my cameras and TTS services were functioning great. However, again over the past month, I noticed my cameras going offline more and more even though they were always available in the Netatmo IOS app. It’s now at the point of them being off line more than online due to a failure to reach our servers. Finally, I submitted a formal support request. As fate would have it my cameras are online at the moment. TTS is even more bizarre. It was coming and going but then stopped performing at all. I use Sonos for playback. Again, the Sonos app, complained that the server was not responding and therefore timed out the request. All my voice recordings are in the TTS folder but do not get played. I tried using Google and then switched to VoiceRSS but still nothing. So I submitted a formal support request for that issue as well. Here is my setup, like I said very vanilla; I would just like it to work with Google Translate or VoiceRSS so I get playback. VoiceRSS is a resource hound but it’s fine for what I’m doing. I’m not sure what specifically you are looking for but you are welcome to jump on my set-up via Teamviewer and have a look around if it would help.
Environment
Home Assistant 0.110.3, Frontend version: 20200519.5 - latest
arch |
armv7l |
chassis |
embedded |
dev |
false |
docker |
true |
hassio |
true |
host_os |
HassOS 3.13 |
installation_type |
Home Assistant |
os_name |
Linux |
os_version |
4.19.114-v7 |
python_version |
3.7.7 |
supervisor |
225 |
timezone |
America/Chicago |
version |
0.110.3 |
virtualenv |
false |
- Home Assistant Core release with the issue: 103.3
- Last working Home Assistant Core release (if known): Unknown - has been going on since the introduction of internal and external urls.
- Operating environment (Home Assistant/Supervised/Docker/venv): Docker
- Integration causing this issue: TTS
- Link to integration documentation on our website: https://www.home-assistant.io/integrations/tts
