Netatmo camera feed stops working after a few hours
I changed my ISP and router recently and since then, I noticed that the camera feed of my Netatmo Presence stops working after a few hours. Everything else is fine : I still get notifications from the webhook, the snapshot of the camera is still updated. But the stream won’t load and I get this error in the logs :
2021-09-11 04:16:01 ERROR (stream_worker) [homeassistant.components.stream.worker] Error opening stream https://prodvpn-eu-1.netatmo.net/restricted/10.255.177.13/<id_1>/<id_2>,,/live/files/high/index.m3u8
When I try this URL in a browser, I get an error 403. The 2nd id is wrong. Maybe it’s supposed to change regularly and the integration doesn’t update it for some reason.
From the developer documentation ( Netatmo Connect | Security API Documentation ) I get a different URL.
vpn_url:"https://prodvpn-eu-1.netatmo.net/restricted/10.255.177.13/<same_id_1>/<different_id_2>,,"
Restarting HA or removing and adding the Netatmo integration again temporarily solves the problem.
Has anyone ever had this issue?
edit: I also feel like it shouldn’t use the vpn_url attribute in the first place but the local_url since my home assistant and my camera are on the same network but local_url is set to null for some reason. Maybe the real problem is here.
Found the solution. I was on the right path. The Netatmo API was sending a wrong local_url in 169.254. Rebooting the camera then HA fixed it.
Just to clarify, this doens’t work anymore right?
Used to have the LocaL url of the camera feed through Netatmo API but I think they removed this option.
– I wanted to get this camera integrated inside frigate but I think I’m dreaming…
