After restarting Netatmo today i got an error for setting up the Netatmo component.
Error during setup of component netatmo
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 148, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/netatmo.py", line 53, in setup
'read_station read_camera access_camera '
File "/srv/homeassistant/lib/python3.5/site-packages/pyatmo.py", line 73, in __init__
self._accessToken = resp['access_token']
TypeError: 'NoneType' object is not subscriptable
This happened after upgrading to HA 0.75.2 as far as i know. Any one got an idea?
After downgrade to 0.74 the component is working again.
Most likely related to changes in HA 0.75 related to the Netatmo component. AFAIK it’s been rewritten to work with a new Netatmo API.
There are more details in the. 75 change log as well as the Development section of the forum here (Testers needed for Netatmo climate (multiple thermostats or valves))
2018-08-23 19:01:43 ERROR (MainThread) [homeassistant.setup] Error during setup of component netatmo
File “/usr/local/lib/python3.6/site-packages/homeassistant/setup.py”, line 148, in _async_setup_component
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/netatmo.py”, line 46, in setup
import pyatmo
File “/usr/local/lib/python3.6/site-packages/pyatmo.py”, line 18, in
from smart_home.PublicData import PublicData
ModuleNotFoundError: No module named ‘smart_home.PublicData’
2018-08-23 19:01:43 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of climate.netatmo. Setup failed for dependencies: netatmo
2018-08-23 19:01:43 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform climate.netatmo: Could not setup all dependencies.
2018-08-23 19:01:43 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of sensor.netatmo. Setup failed for dependencies: netatmo
2018-08-23 19:01:43 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.netatmo: Could not setup all dependencies.
Would you mind sharing your setup ? I am running HA with docker in a VM from esx 6.5
It looks like python is missing a dependency but at least on the host everything is there …
018-10-08 10:40:40 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform netatmo2
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/config/custom_components/climate/netatmo2.py”, line 70, in setup_platform
for room_name in room_data.get_room_names():
File “/config/custom_components/climate/netatmo2.py”, line 316, in get_room_names
self.setup()
File “/config/custom_components/climate/netatmo2.py”, line 331, in setup
self.homestatus = lnetatmo.HomeStatus(self.auth, home=self.home)
File “/config/deps/lib/python3.6/site-packages/netatmo_home/Thermostat.py”, line 125, in init
self.rawData = resp[‘body’][‘home’]
KeyError: ‘home’
2018-10-08 10:40:41 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 339, in _async_add_entity
msg)
homeassistant.exceptions.HomeAssistantError: Entity id already exists: switch.pihole_switch
2018-10-08 10:40:41 ERROR (MainThread) [homeassistant.components.sensor] netatmo: Error on device update!
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 251, in _async_add_entity
await entity.async_device_update(warning=False)
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py”, line 352, in async_device_update
yield from self.hass.async_add_job(self.update)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/netatmo.py”, line 269, in update
if data[‘rf_status’] >= 90:
KeyError: ‘rf_status’
