The first thing that I notice apart from the exceotions happening there, you have to use your own Netatmo dev account and configure that in configuration.yaml
. Please remove the interation, add the config, restart HA and add the integration again using configuration.yaml
Hi Tobi
I have been having a similar issue, the cameras have become unavailable in the integration after restarts of home assistant, uninstalling and reinstalling the integration worked the first time but now no cameras are discovered… I am using a dev account and the configuration yaml option in the integration, no web hook ban, and i have tried registering and unregistered the web hooks. Any thoughts?
Logger: homeassistant.components.camera
Source: components/netatmo/data_handler.py:117
Integration: Camera ([documentation](https://www.home-assistant.io/integrations/camera), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+camera%22))
First occurred: 11:55:58 (1 occurrences)
Last logged: 11:55:58
Error while setting up netatmo platform for camera
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 193, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/netatmo/camera.py", line 94, in async_setup_entry
async_add_entities(await get_entities(), True)
File "/usr/src/homeassistant/homeassistant/components/netatmo/camera.py", line 53, in get_entities
await data_handler.register_data_class(
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 149, in register_data_class
await self.async_fetch_data(
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 117, in async_fetch_data
self.data[data_class_entry] = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/site-packages/pyatmo/camera.py", line 122, in __init__
self.update_camera_urls(camera_id)
File "/usr/local/lib/python3.8/site-packages/pyatmo/camera.py", line 179, in update_camera_urls
self.cameras[home_id][camera_id]["local_url"] = check_url(
File "/usr/local/lib/python3.8/site-packages/pyatmo/camera.py", line 175, in check_url
return resp.get("local_url")
AttributeError: 'NoneType' object has no attribute 'get'
To make sure that you’re actually using the yaml config please remove the integration, restart HA and add the integration again.
It should look like this:
Hi Tobi,
I have tried re-installing the integration using configuration. Yaml options several times. However the same result unfortunately. All other devices are discovered except the camera.
I will post a copy of the error log later today.
Br
Stian
I have the same problem. all weather-station related products are discovered fine, but my cameras are not. I’m on the latest version. I’ve switched from Synology to raspberry installation, but have the same problem. Everything else works fine
Does the integration panel also state that you’re using configuration.yaml
rather than HA Cloud?
HA Cloud
vs.
Please check your logs for Netatmo related messages (ideally turn on debug logging) to gather some insights.
As I wrote earlier, please remove the integration, restart HA and add the integration again.
Hi again,
Removed, rebooted and re installed the integration.
Logs shows the following:
Integration: Kamera ([documentation](https://www.home-assistant.io/integrations/camera), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+camera%22))
First occurred: 7:13:12 (1 occurrences)
Last logged: 7:13:12
Hi Tobi
I cant really shed much light on the issue. But for me after removing the integration, updating to 0.115.4, and then preforming the reintegration of Netatmo all my devices including the cameras have come back.
I also was definitely using the configuration.yaml option as you displayed. One thing i did notice however that trying to access dev.netatmo.com over the weekend was producing a blank page. So it may have been an issue with their server as i was still receiving the webhook events from my cameras in HA.
Hello again. Some more follow up, after updating to 0.115.5 i have lost the cameras from the integration again, they where marked as orphaned.
Tried the reinstall of the component (using yaml) and only the weather station entities are discovered non of the three cameras. The debug logs dont give any indication of an issue other than no mention of cameras at all, the webhook is successfully registered, and all the weather station sensors added
2020-09-30 08:32:29 DEBUG (MainThread [homeassistant.components.netatmo.netatmo_entity_base] New client sensor.netatmo ...........
etc
Not sure what this one is but thats the only log that looks unusual:
2020-09-30 08:32:29 DEBUG (MainThread) [homeassistant.components.netatmo.data_handler] Data class HomeCoachData added
The cameras are just not being discovered. Tried creating a new app in dev.netatmo.com and the same result. All the webhook triggers from the cameras are received by HA though.
i have the same problem. deleted the integration, rebooted the server and added the integration again. all my weather station sensors are found and work fine…cameras aren’t discovered at all. no error
Yes definitely using the configuration.yaml within the integrations page.
i’m using cloud access
That’s probably your issue then as has been mentioned your meant to be using the configuration.yaml
ah i see, that’s my bad, i’ll try that, thanks
