Netatmo: On two houses, only one appear
First day on HA :). I have two houses on my Netatmo account.
When I set up Home Assistant which is in my primary house, only two cameras of the secondary house are accessible with streaming. On the primary house, I have the cameras and thermostats listed but no connection is done.
I tried to create my own credentials in the developer space of Netatmo but same thing.
Please note the camera of the primary house has uploaded one image after I did a reload of the add-on. But that’s it. Nothing else after. I see it listed on the dashboard but no streaming.
The webhooks in the developper space are displayed as working. I set the public URL in Home Assistant Cloud.
Thank you so much for your help.
Ad
See screenshot:
See logs
2024-11-25 22:27:35.634 ERROR (MainThread) [homeassistant.components.camera] Error adding entity camera.camera_devant for domain camera with platform netatmo
  File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 663, in _request
    conn = await self._connector.connect(
  File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 538, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1050, in _create_connection
    _, proto = await self._create_direct_connection(req, traces, timeout)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1353, in _create_direct_connection
    transp, proto = await self._wrap_create_connection(
  File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1109, in _wrap_create_connection
    sock = await aiohappyeyeballs.start_connection(
  File "/usr/local/lib/python3.12/site-packages/aiohappyeyeballs/impl.py", line 82, in start_connection
    sock = await _connect_sock(
  File "/usr/local/lib/python3.12/site-packages/aiohappyeyeballs/impl.py", line 174, in _connect_sock
    await loop.sock_connect(sock, address)
  File "/usr/local/lib/python3.12/asyncio/selector_events.py", line 641, in sock_connect
    return await fut
asyncio.exceptions.CancelledError
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 599, in _async_add_entities
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 918, in _async_add_entity
    await entity.add_to_platform_finish()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1366, in add_to_platform_finish
    await self.async_internal_added_to_hass()
  File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 791, in async_internal_added_to_hass
    await self.async_refresh_providers(write_state=False)
  File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 809, in async_refresh_providers
    new_provider = await self._async_get_supported_webrtc_provider(
  File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 833, in _async_get_supported_webrtc_provider
    return await fn(self.hass, self)
  File "/usr/src/homeassistant/homeassistant/components/camera/webrtc.py", line 351, in async_get_supported_provider
    if not providers or not (stream_source := await camera.stream_source()):
  File "/usr/src/homeassistant/homeassistant/components/netatmo/camera.py", line 200, in stream_source
    await self.device.async_update_camera_urls()
  File "/usr/local/lib/python3.12/site-packages/pyatmo/modules/module.py", line 502, in async_update_camera_urls
    self.local_url = await self._async_check_url(
  File "/usr/local/lib/python3.12/site-packages/pyatmo/modules/module.py", line 514, in _async_check_url
    resp = await self.home.auth.async_post_api_request(
  File "/usr/local/lib/python3.12/site-packages/pyatmo/auth.py", line 86, in async_post_api_request
    return await self.async_post_request(
  File "/usr/local/lib/python3.12/site-packages/pyatmo/auth.py", line 105, in async_post_request
    async with self.websession.post(
  File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 1360, in __aenter__
    self._resp: _RetType = await self._coro
  File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 578, in _request
    with timer:
  File "/usr/local/lib/python3.12/site-packages/aiohttp/helpers.py", line 749, in __exit__
    raise asyncio.TimeoutError from exc_val
TimeoutError
2024-11-25 22:36:16.298 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [546721934800] Error handling message: Camera is off (home_assistant_error) Ad from fe80::34:c19b:8639:c4c8 (Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/18.1.1 Safari/605.1.15)
2024-11-25 22:36:17.634 ERROR (MainThread) [homeassistant.components.camera] Timeout getting stream source
The answer is 42
(and …yes…it is in english)
What he/she meant to say is that this is an English-language forum, per item #0 of this sticky post (that he/she linked in their reply):
https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371#zero-language-3
Hi Ad,
Please read the FAQ before posting. This is an English only forum.
Please translate the original for us or risk that this POST will be closed.
How to help us help you - or How to ask a good question.
Veuillez lire la FAQ avant de poster. Ce forum est uniquement en anglais.
Veuillez traduire l’original pour nous ou risquer que ce POST soit fermé.
