Its marked stale and cancelt. Why? Can we make this happen in ont of the upcomming releases?
The API does not provide reliable enough feedback to make it a proper light platform. The services to toggle lights will come back soon though.
Hi Tobi,
understood. Thats good news. Missing that feature a lot. If I can be of any help, let me know.
Regards
Ralf
Hi Tobi,
is there any update available on the lights of the netatmo camera being able to turn on/off from HA?
Have a great weekend.
Ralf
This is possible since 0.114. Apparently it got lost then the release notes were put together.
You are my hero. Just updated. Works. Thank you.
That is very kind. Thank you.
Dear @cgtobi,
First, thanks for all your recent efforts with Netatmo!
I have problems with my three Presenceâs floodlights. The lights seem to be correctly set up (not unavailable, and my webhooks status is OK in Netatmo dev site), but when trying to use them, I get this (IDs partly redacted):
Logger: pyatmo.helpers
Source: /usr/local/lib/python3.8/site-packages/pyatmo/camera.py:595
First occurred: 29 septembre 2020 Ă 19:58:44 (11 occurrences)
Last logged: 17:26:35
* 400 - Bad request - Invalid device_id, 70:ee:50:xx:xx:xx (21) when accessing 'https://api.netatmo.com/api/setstate'
Same error when using the netatmo.set_camera_light
service.
The rest is working fine (camera images, sensors based on netatmo_event
, etc.)
Any idea?
Thanks.
Has this always been this way?
I never had the lights working (through HA), so I unregistered / registered and checked the webhooks, the lights were then available, but with the errors mentioned when actioned.
I just checked with a few users I know and at least this doesnât seem to be a general issue. Now we have to find out why youâre having trouble. Could you please turn on debug logging for the Netatmo integration and check your logs?
Just PMed you my logs, thanks!
Hi everybody !!
Thank you @cgtobi for your work on the Netatmo integration !
Does it possible to toggle the motion detection ?
thank you
To my knowledge Netatmo does not support that. You can toggle monitoring on/off, but this means turning the camera on/off.
Oh OK, thank you for your answer, I will use this method !
Iâve got an other question: how to receive a notification when the camera is off ?
I tried with this automation, but with no result:
- alias: Notif William Caméra OFF
- event_type: netatmo_event
platform: event
event_data:
type: off
- service: notify.notify_will
message: "Camera is out !"
Youâre actually pretty close:
- platform: event
event_data:
type: 'off'
Hi !
I find where is my problemâŠ
The entity camera.netatmo_xxx
does not refresh !
But it pretty ennoying, because Iâve got no errorâŠ
Did you see this case before ?
Thank you !!
You mean the camera does not react to commands from HA?
Yes it does !
These commands work:
- service: camera.turn_on
entity_id: camera.netatmo_camera_arriere
or
- service: camera.turn_off
But states and attributes are not updated !
Itâs for this reason my notifications do not work !
Can you double check that webhook is working for Netatmo?
