I guess I will have to try the event detection again; I was never able to get it to work.
Looks like you have the exact opposite issues as I do. My cameras display but I get not events.
Everything that you have in you states display seems to match mine; so I don’t see how you are getting the events from the entity.
What do you have listed on the integration for entities. I only have the cameras listed.
I have some Netatmo Presence and some UniFI G4 Pro.
I have no issue to get notification for “person” using the G4 Pro , however I can’t manage to make it work with “human” for the Netatmo.
That must be it, I was listening to netatmo_event but nothing was found at all.
Even though the livestream is working I just realised I have a lot of issue in the logs
2021-03-22 19:31:47 ERROR (MainThread) [homeassistant.components.netatmo] Error during webhook registration - 400 - Bad request - Allowed ports for webhooks are 80, 88, 443 and 9443. (21) when accessing ‘https://api.netatmo.com/api/addwebhook’
2021-03-22 19:31:44 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet. Retrying in 30 seconds.
Look at Configuration > Home Assistant Cloud, scroll down and you can see the list of all webhooks HA is listening to. When you install the Netatmo integration, there should be a webhook Netatmo created automatically.
But AFAIK webhook should not be used when you issue a command to the camera, but rather to receive a message from the camera. Your issue seems to come from something else than webhook. Did you try to uninstall and reinstall the integration ?
No, didn’t try to remove and re-add the integration mainly because I have a lot of Netatmo sensors and automation relying on them so I was a bit reluctant.
Will remove and re-add change the names of my entities?
When cameras don’t work the problem often is because HA Cloud Link is used instead of an individual Netatmo dev account configured in your configuration.yaml.
Agreed, I used the cloud link installation. Sorry. I removed the integration, restarted HA. It finds the integration. I install it again. Only the weather entities. Not the cameras are found. I am lost. Any idea how I can debug this?
