Logs:
2020-12-03 10:01:06 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for circadian_lighting which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-12-03 10:01:06 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
However, I have some configuration of logs in configuration.yaml which should be more detailed but I have never needed them. If you point me where to get them, I can provide you with more details.
I added external configuration url from the nabu casa interface for remote connection. However, remote access page shows in the first sentence that I do not need to configure anything when using nabu casa. If that is not true, let’s polish the documentation.
