Hi All
I’m using Netatmo thermostats and here is what I experience:
- I change the schedule using the built in service, on the device itself.
- The schedule changes correctly in the (phone)APP and on web immediately
- The state changes correctly in HA . also immediately
- After about 30 seconds, the state in HA changes back to the previous one.
- In netatmo app, the schedule remains correct.
- (If I leave HA alone, the state updates to the correct one after a some hours.)
Here’s the info…
- I’m using reverse proxy via Cloudflare. I can see in my firewall events that Netatmo messages are allowed through.
- I can see in the HA log that the webhook registers correctly.
- Webhooks are not banned in Netatmo
I have un-registered and registered the webhook. Logs below. I have anonymized the logs - let me know if it’s too much.(or too little )
Also, I can see that the state of mit_hjem changed at 02.15.09 AM - there are no HA log entries at that time.
Hope someone can help here
2022-12-22 23:18:50.883 INFO (MainThread) [homeassistant.helpers.script.websocket_api_script] websocket_api script: Running websocket_api script
2022-12-22 23:18:50.885 INFO (MainThread) [homeassistant.helpers.script.websocket_api_script] websocket_api script: Executing step call service
2022-12-22 23:18:50.887 DEBUG (MainThread) [homeassistant.components.netatmo] Unregister Netatmo webhook ([WEBHOOK ID])
2022-12-22 23:18:50.895 INFO (MainThread) [homeassistant.components.netatmo.data_handler] Netatmo webhook unregistered
2022-12-22 23:19:11.751 INFO (MainThread) [homeassistant.helpers.script.websocket_api_script] websocket_api script: Running websocket_api script
2022-12-22 23:19:11.752 INFO (MainThread) [homeassistant.helpers.script.websocket_api_script] websocket_api script: Executing step call service
2022-12-22 23:19:11.931 INFO (MainThread) [homeassistant.components.netatmo] Register Netatmo webhook: https://xxxx.yyy.dk/api/webhook/[WEBHOOK ID]
2022-12-22 23:19:12.068 DEBUG (MainThread) [homeassistant.components.netatmo.webhook] Got webhook data: {'user_id': '[MY ID]', 'user': {'id': '[MY ID]', 'email': '[MY EMAIL]'}, 'push_type': 'webhook_activation'}
2022-12-22 23:19:12.069 DEBUG (MainThread) [homeassistant.components.netatmo.webhook] None: {'user_id': '[MY USER]', 'user': {'id': '[MY ID]', 'email': '[MY EMAIL]'}, 'push_type': 'webhook_activation'}
2022-12-22 23:19:12.077 INFO (MainThread) [homeassistant.components.netatmo.data_handler] Netatmo webhook successfully registered
2022-12-22 23:20:48.590 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [547659167440] Initialized trigger
2022-12-22 23:21:54.160 INFO (MainThread) [homeassistant.components.automation.test2_set_value_from_helper4] test2_set_value_from_helper4: Running automation actions
2022-12-22 23:21:54.161 INFO (MainThread) [homeassistant.components.automation.test2_set_value_from_helper4] test2_set_value_from_helper4: Executing step call service
2022-12-22 23:21:54.174 DEBUG (MainThread) [homeassistant.components.netatmo.select] Setting [ENTITY ID] schedule to Standard ([ENTITY ID])
2022-12-22 23:21:54.502 DEBUG (MainThread) [homeassistant.components.netatmo.webhook] Got webhook data: {'user_id': '[MY ID]', 'user': {'id': '[MY ID]', 'email': '[MY EMAIL]'}, 'home_id': '[HOME ID]', 'event_type': 'schedule', 'schedule_id': '5dea735a4aa11372751890c6', 'previous_schedule_id': '5e4d7f224aa113fa7726c2f4', 'push_type': 'home_event_changed'}
2022-12-22 23:21:54.503 DEBUG (MainThread) [homeassistant.components.netatmo.webhook] schedule: {'user_id': '[MY USER]', 'user': {'id': '[MY ID]', 'email': '[MY EMAIL]'}, 'home_id': '[HOME ID]', 'event_type': 'schedule', 'schedule_id': '5dea735a4aa11372751890c6', 'previous_schedule_id': '5e4d7f224aa113fa7726c2f4', 'push_type': 'home_event_changed'}
2022-12-22 23:25:50.392 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [547659363472] Connection closed by client
2022-12-22 23:33:03.867 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [547631324928] Connection closed by client
2022-12-22 23:33:03.873 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [547636643776] Connection closed by client
2022-12-22 23:33:25.347 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [547630637760] Connection closed by client
2022-12-22 23:38:27.546 DEBUG (MainThread) [homeassistant.components.netatmo.select] Setting 5c03af40ea00a01a388baf1e schedule to Arbejder hjemme (61f2b0372066e413021525f5)
2022-12-22 23:38:27.847 DEBUG (MainThread) [homeassistant.components.netatmo.webhook] Got webhook data: {'user_id': '[MY ID]', 'user': {'id': '[MY ID]', 'email': '[MY EMAIL]'}, 'home_id': '[HOME ID]', 'event_type': 'schedule', 'schedule_id': '61f2b0372b66e413021525f4', 'previous_schedule_id': '5dea735a41a11372751890c6', 'push_type': 'home_event_changed'}
2022-12-22 23:38:27.851 DEBUG (MainThread) [homeassistant.components.netatmo.webhook] schedule: {'user_id': '[MY ID]', 'user': {'id': '[MY ID]', 'email': '[MY EMAIL]'}, 'home_id': '[HOME ID]', 'event_type': 'schedule', 'schedule_id': '61f2b0372b66e413021525f5', 'previous_schedule_id': '5dea735a41a11372751890c6', 'push_type': 'home_event_changed'}
2022-12-22 23:41:43.110 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [547633724960] Connection closed by client
2022-12-22 23:43:40.004 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [547630641360] Connection closed by client
2022-12-22 23:45:04.414 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [547635915808] Connection closed by client
2022-12-22 23:53:37.494 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [547658760256] Connection closed by client
2022-12-22 23:55:01.412 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [547896889248] Connection closed by client
