Since a few weeks now I’m having issues with accessing my two Netatmo Welcome cameras and four Netatmo Radiator valves in Home Assistant. FYI, I also have an Netatmo weather station that is working perfect in home assistant.
2019-07-20 22:06:53 INFO (SyncWorker_15) [homeassistant.components.netatmo.sensor] No home coach devices found
2019-07-20 22:06:53 INFO (SyncWorker_9) [homeassistant.components.netatmo.sensor] Netatmo refresh interval reset to 300 seconds
Did you try without the explicit config of climate and camera? Discovery should be able to detect them. The No home coach devices found message is a bit confusing but safe to ignore if you don’t have home coach devices.
The same result, radiator valves and camera are not present in home assistant. Whilst the weather station modules are there. Any idea how I can do some more debugging? My debug rules are now:
logger:
default: critical
logs:
homeassistant.components.netatmo: info
Thanks for all the help, please find below the logs.
It looks like it finds the weather station, and indicates that there are no thermostat devices available. Would the radiator valves count as thermostat devices? No mentioning about my two welcome camera’s.
Is there any way to view the direct API (JSON?) response from Netatmo on the list of devices? I allready tried to create an new APP with App secret etc.
2019-07-22 20:43:07 DEBUG (SyncWorker_16) [homeassistant.components.netatmo.climate] No thermostat devices available.
2019-07-22 20:48:56 INFO (SyncWorker_7) [homeassistant.components.netatmo.sensor] No home coach devices found
2019-07-22 20:48:56 DEBUG (SyncWorker_9) [homeassistant.components.netatmo.sensor] WeatherStationData detected!
2019-07-22 20:48:56 INFO (SyncWorker_9) [homeassistant.components.netatmo.sensor] Netatmo refresh interval reset to 463 seconds
2019-07-22 20:56:41 DEBUG (SyncWorker_12) [homeassistant.components.netatmo.sensor] WeatherStationData detected!
2019-07-22 20:56:41 INFO (SyncWorker_12) [homeassistant.components.netatmo.sensor] Netatmo refresh interval reset to 300 seconds
The zeroconf message is probably related to homekit not the netatmo integration. Did you add any new netatmo devices to your netatmo account? The issue described above usually comes from a very specific circumstance which soon will be addressed.
Could you please verify that everything works before 0.96.3?
I Added a new sensor to the weather Station Last week, but everything worked fine afterwards.
I can say that with 96.x everything worked fine until 96.3.
I can hardly say which 96.x Version I had, but I know that After 96.3 the valves and Camera where Not discovered anymore.
So, I downgraded to every version from now till 0.95.4. even with 0.95.4 my valves and netatmo present are not discovered.
I restarted hass.io again and even used my second “app” client.
This didn’t work either.
Now I’m back on 0.96.5.
Ok, I would have been surprised since I am not aware of any related changes. But the good news for you, the upstream changes just got merged so the fix for this issue should be part of the beta next week.
