I would like to suggest to evaluate the possibility of integrating Netro products (http://www.netrohome.com/), especially the sprinkler sytems, into Home Assistant.
This would allow automation of the sprinkler system at house.
I’m also interested in this…
Please
Also interested.
Me too please !
Anyone done this yet - I am also interested
One up!!
After this too!
Yes, please! I am also interested.
Dear all,
I’ve just heard that Netro has published their own API. Did someone already examine this ?
@Bowie @alnavasa @juanbrunette @virgilinfo @Yoryino @StefanoGiu @iphoust84
Guys,
As indicated in my post, after a lot of pushing, Netro has published their API. As I’m a newbie in this space, and you might have experience, please have a look and maybe create something ?
Here you find more information on their API : https://www.netrohome.com/shop/articles/10
I have Zero coding knowledge, but that api looks easy to start dealing with, not that sophisticated.
I created the following sensors:
- platform: rest
name: Centralina Irrigazione - Zona 1
json_attributes_path: "$.[0]"
json_attributes:
- local_start_time
- local_end_time
- local_date
- source
- status
resource_template: http://api.netrohome.com/npa/v1/schedules.json?key=XXXXXXXXXXXX&start_date={{now().strftime('%Y-%m-%d')}}&end_date={{now().strftime('%Y-%m-%d')}}&zones=[1]
scan_interval: 600
value_template: "{{ value_json.data.schedules[0].status }}"
- platform: rest
name: Centralina Irrigazione - Zona 2
json_attributes:
- local_start_time
- local_end_time
- local_date
- source
- status
resource_template: http://api.netrohome.com/npa/v1/schedules.json?key=XXXXXXXXXXXX&start_date={{now().strftime('%Y-%m-%d')}}&end_date={{now().strftime('%Y-%m-%d')}}&zones=[2]
scan_interval: 600
- platform: rest
name: Centralina Irrigazione - Zona 3
json_attributes:
- local_start_time
- local_end_time
- local_date
- source
- status
resource_template: http://api.netrohome.com/npa/v1/schedules.json?key=XXXXXXXXXXXX&start_date={{now().strftime('%Y-%m-%d')}}&end_date={{now().strftime('%Y-%m-%d')}}&zones=[3]
scan_interval: 600
- platform: rest
name: Centralina Irrigazione - Zona 4
json_attributes:
- local_start_time
- local_end_time
- local_date
- source
- status
resource_template: http://api.netrohome.com/npa/v1/schedules.json?key=XXXXXXXXXXXX&start_date={{now().strftime('%Y-%m-%d')}}&end_date={{now().strftime('%Y-%m-%d')}}&zones=[4]
scan_interval: 600
- platform: rest
name: Centralina Irrigazione - Zona 5
json_attributes:
- local_start_time
- local_end_time
- local_date
- source
- status
resource_template: http://api.netrohome.com/npa/v1/schedules.json?key=XXXXXXXXXXXX&start_date={{now().strftime('%Y-%m-%d')}}&end_date={{now().strftime('%Y-%m-%d')}}&zones=[5]
scan_interval: 600
- platform: rest
name: Centralina Irrigazione - Zona 6
json_attributes:
- local_start_time
- local_end_time
- local_date
- source
- status
resource_template: http://api.netrohome.com/npa/v1/schedules.json?key=XXXXXXXXXXXX&start_date={{now().strftime('%Y-%m-%d')}}&end_date={{now().strftime('%Y-%m-%d')}}&zones=[6]
scan_interval: 600
- platform: rest
json_attributes:
- data
resource_template: https://api.netrohome.com/npa/v1/info.json?key=XXXXXXXXXXXX
scan_interval: 60
value_template: "{{ value_json.data.device.status }}"
sensors:
centralina_irrigazione_name:
value_template: >
{{ state_attr('sensor.centralina_irrigazione', 'data')['device']['name'] }}
centralina_irrigazione_serial:
value_template: >
{{ state_attr('sensor.centralina_irrigazione', 'data')['device']['serial'] }}
centralina_irrigazione_zone_num:
value_template: >
{{ state_attr('sensor.centralina_irrigazione', 'data')['device']['zone_num'] }}
centralina_irrigazione_status:
value_template: >
{{ state_attr('sensor.centralina_irrigazione', 'data')['device']['status'] }}
centralina_irrigazione_version:
value_template: >
{{ state_attr('sensor.centralina_irrigazione', 'data')['device']['version'] }}
centralina_irrigazione_sw_version:
value_template: >
{{ state_attr('sensor.centralina_irrigazione', 'data')['device']['sw_version'] }}
centralina_irrigazione_zone1_name:
value_template: >
{{ state_attr('sensor.centralina_irrigazione', 'data')['device']['zones'][0]['name'] }}
centralina_irrigazione_zone2_name:
value_template: >
{{ state_attr('sensor.centralina_irrigazione', 'data')['device']['zones'][1]['name'] }}
centralina_irrigazione_zone3_name:
value_template: >
{{ state_attr('sensor.centralina_irrigazione', 'data')['device']['zones'][2]['name'] }}
centralina_irrigazione_zone4_name:
value_template: >
{{ state_attr('sensor.centralina_irrigazione', 'data')['device']['zones'][3]['name'] }}
centralina_irrigazione_zone5_name:
value_template: >
{{ state_attr('sensor.centralina_irrigazione', 'data')['device']['zones'][4]['name'] }}
centralina_irrigazione_zone6_name:
value_template: >
{{ state_attr('sensor.centralina_irrigazione', 'data')['device']['zones'][5]['name'] }}
And then the following scripts that I use on the lovelace to start and stop the watering:
water_a_zone:
alias: Innaffia una zona
sequence:
- choose:
- conditions:
- condition: template
value_template: >
{{ states["sensor.centralina_irrigazione"].state == 'ONLINE' }}
sequence:
- service: rest_command.water_start
data_template:
time: >
{{minuti}}
zone: >
{{zona}}
- conditions:
value_template: >
{{ states["sensor.centralina_irrigazione"].state == 'WATERING' }}
sequence:
- service: rest_command.water_stop
- service: notify.allarme
data_template:
title: >-
{% if (states["sensor.centralina_irrigazione"].state == 'ONLINE')%}
đź’§ *Innaffia Zona*
{% elif (states["sensor.centralina_irrigazione"].state == 'WATERING')%}
đź’§ *Ferma Irrigazione*
{% elif (states["sensor.centralina_irrigazione"].state == 'OFFLINE')%}
đź’§ *Centralina Offline*
{% else %}
đź’§ *Stato Centralina Sconosciuto*
{% endif %}
message: >-
Innaffio la zona {{zona}} per {{minuti}} minuti
Fermo l'irrigazione
Centralina Offline
{% else %}
{% endif %}
- delay:
seconds: 3
- service: homeassistant.update_entity
entity_id: sensor.centralina_irrigazione
entity_id: sensor.centralina_irrigazione_zona_1
entity_id: sensor.centralina_irrigazione_zona_2
entity_id: sensor.centralina_irrigazione_zona_3
entity_id: sensor.centralina_irrigazione_zona_4
entity_id: sensor.centralina_irrigazione_zona_5
entity_id: sensor.centralina_irrigazione_zona_6
entity_id: sensor.centralina_irrigazione_name
entity_id: sensor.centralina_irrigazione_serial
entity_id: sensor.centralina_irrigazione_status
entity_id: sensor.centralina_irrigazione_sw_version
entity_id: sensor.centralina_irrigazione_version
entity_id: sensor.centralina_irrigazione_zone1_name
entity_id: sensor.centralina_irrigazione_zone2_name
entity_id: sensor.centralina_irrigazione_zone3_name
entity_id: sensor.centralina_irrigazione_zone4_name
entity_id: sensor.centralina_irrigazione_zone5_name
entity_id: sensor.centralina_irrigazione_zone6_name
entity_id: sensor.centralina_irrigazione_zone_num
with rest_command:
water_start:
url: https://api.netrohome.com/npa/v1/water.json
method: POST
headers:
accept: "application/json, text/html"
user-agent: 'Mozilla/5.0 {{ useragent }}'
payload: '{"key":"XXXXXXXXXXXX", "zones": [{{zone}}], "duration":{{time}} }'
content_type: 'application/json; charset=utf-8'
verify_ssl: true
water_stop:
url: https://api.netrohome.com/npa/v1/stop_water.json
method: POST
headers:
payload: '{"key":"XXXXXXXXXXXX" }'
verify_ssl: true
You willl need to replace XXXXXXX with your tokenkey…
This part will send a message to my TelegramBot
I would also love to see an integration. If I manage to get my head around Python I may give it a try.
In the meantime, following @StefanoGiu’s code, I’ve wrapped it all in a package with one API call for all the sensors to avoid reaching the quota.
I’ve got 6 zones but only pasted the code for 2 for simplicity but it can be adapted to N zones.
rest:
- resource_template: http://api.netrohome.com/npa/v1/schedules.json?key={{states('sensor.netro_api_key')}}&start_date={{utcnow().strftime('%Y-%m-%d')}}
scan_interval: 90
- name: Netro Zone 1 Raw
value_template: >
{% set current_zone = ( value_json.data.schedules | selectattr("zone","eq", 1) | list ) %}
{{ current_zone | selectattr("status","ne","EXECUTED") | list | last }}
- name: Netro Zone 2 Raw
value_template: >
{% set current_zone = ( value_json.data.schedules | selectattr("zone","eq", 2) | list ) %}
rest_command:
netro_irrigation_start:
method: POST
headers:
payload: '{"key":"{{states("sensor.netro_api_key")}}", "zones": [{{zone}}], "duration":{{duration}} }'
verify_ssl: true
netro_irrigation_stop:
method: POST
headers:
payload: '{"key":"{{states("sensor.netro_api_key")}}" }'
verify_ssl: true
script:
description: Starts Netro Irrigation for a given zone
sequence:
- service: rest_command.netro_irrigation_start
data_template:
duration: "{{duration}}"
zone: "{{zone}}"
- delay:
seconds: 5
entity_id: sensor.netro_zone_1_raw # any zone would do
description: Stops current Netro Irrigation
sequence:
- service: rest_command.netro_irrigation_stop
- delay:
seconds: 5
sensors:
netro_api_key:
friendly_name: "Netro API Key"
value_template: !secret netro_key
netro_zone_1:
friendly_name: "Netro Zone 1 Status"
value_template: >
{%- set val = ((states('sensor.netro_zone_1_raw') or "{}") | replace("'",'"') | from_json).status %}
{{- "on" if val == "EXECUTING" else "scheduled" if val == "VALID" else "off" }}
attribute_templates:
start_time: >
{{ ((states('sensor.netro_zone_1_raw') or "{}") | replace("'",'"') | from_json).start_time }}
end_time: >
{{ ((states('sensor.netro_zone_1_raw') or "{}") | replace("'",'"') | from_json).end_time }}
local_start_time: >
{{ ((states('sensor.netro_zone_1_raw') or "{}") | replace("'",'"') | from_json).local_start_time }}
local_end_time: >
{{ ((states('sensor.netro_zone_1_raw') or "{}") | replace("'",'"') | from_json).local_end_time }}
duration_minutes: >
{%- set start_time = ((states('sensor.netro_zone_1_raw') or "{}") | replace("'",'"') | from_json).start_time %}
{%- set end_time = ((states('sensor.netro_zone_1_raw') or "{}") | replace("'",'"') | from_json).end_time %}
{{- ((as_timestamp(end_time) - as_timestamp(start_time)) / 60) | int }}
source: >
{{ ((states('sensor.netro_zone_1_raw') or "{}") | replace("'",'"') | from_json).source }}
netro_zone_2:
friendly_name: "Netro Zone 2 Status"
value_template: >
{%- set val = ((states('sensor.netro_zone_2_raw') or "{}") | replace("'",'"') | from_json).status %}
start_time: >
{{ ((states('sensor.netro_zone_2_raw') or "{}") | replace("'",'"') | from_json).start_time }}
end_time: >
{{ ((states('sensor.netro_zone_2_raw') or "{}") | replace("'",'"') | from_json).end_time }}
local_start_time: >
{{ ((states('sensor.netro_zone_2_raw') or "{}") | replace("'",'"') | from_json).local_start_time }}
local_end_time: >
{{ ((states('sensor.netro_zone_2_raw') or "{}") | replace("'",'"') | from_json).local_end_time }}
duration_minutes: >
{%- set start_time = ((states('sensor.netro_zone_2_raw') or "{}") | replace("'",'"') | from_json).start_time %}
{%- set end_time = ((states('sensor.netro_zone_2_raw') or "{}") | replace("'",'"') | from_json).end_time %}
source: >
{{ ((states('sensor.netro_zone_2_raw') or "{}") | replace("'",'"') | from_json).source }}
switch:
switches:
netro_zone_1:
value_template: "{{ is_state('sensor.netro_zone_1','on')}}"
turn_on:
service: script.netro_irrigation_start
zone: "1"
duration: "5"
turn_off:
service: script.netro_irrigation_stop
netro_zone_2:
value_template: "{{ is_state('sensor.netro_zone_2','on')}}"
turn_on:
zone: "2"
duration: "5"
turn_off:
Hope it helps!
Thank you, this was really helpful to me! Does anyone know how i can format the date time for outputting something like this?
{{ ((states('sensor.netro_front_zone_raw') or "{}") | replace("'",'"') | from_json).start_time }}
At the moment it outputs canonical “2021-05-30T06:00:00” but i would just like it to display like “Sunday, May 30, 06:00”
I’m a newbie at this so would appreciate any help
I’m presently using a 6 zones Rain Bird ESP-TM2 but saw the Netro 12 zones on Amazon. Is this easy to integrate into hassio?
I found Netro relatively easy to integrate. Just need some help with formatting etc.
How shall I do to integrate in my HA? I have Hassio. I understand this is Python.
