Thank you for the the pull reqest @NotoriousBDG . I merged it and NUT builds on latest stable hassio.
Got this setup and working with my APC Back-UPS pro 1500 but i can not get the current wattage to show. I can get the ups.realpower.nominal to show but this is not the current load on the system in watts. Any body got an idea how to get this to show?
help pls
starting version 3.2.4
Network UPS Tools - UPS driver controller 3.6.0-5670-ga94ef24fb3
Network UPS Tools - PowerCom protocol UPS driver 0.17 (3.6.0-5670-ga94ef24fb3)
Unable to open auto: No such file or directory
Things to try:
- Check 'port=' in ups.conf
- Check owner/permissions of all parts of path
Fatal error: unusable configuration
Driver failed to start (exit status=1)
Hi, I’ve added the repo but i’m not able to install the add-on
the “install” label turns red after a few seconds without install the add-on
any help?
hass.io v 0.69.0
I have the same problem, the build fails in hassio 0.69.0.
I opened an issue in https://github.com/asciinaut/hassio-addons/issues/2 .
It works all right. Thank you very much!
First of all, great work!
Unfortunately I can not install the add-on. It does not complete the installation process and the ‘instal’ button turns red.
Am I too incompetent to do it?
Thank you
I’m having a similar problem. Addon stopped working so I uninstalled and can’t reinstall.
Just tried the forked repo and all working now. Thanks Network UPS Tools add-on
I’ve installed the forked repo from colindunn but i have an 2.2kVA APC Smart UPS with serial communication. I’ve connected it with the same serial cable it was working on a windows PC and plugged a usb-serial converter in the raspi 3B+. Hassio reports the following hardware:
Hardware
- serial:
- /dev/ttyAMA0
- /dev/ttyUSB0
so in the add on configuration i just mofified this in the standard configuration:
“upsname”: “ups”,
“driver”: “apcsmart”,
“port”: “/dev/ttyUSB0”
now when i try to start the service i get the following:
Network UPS Tools - UPS driver controller 3.8.0-3727-geade014bef
Network UPS Tools - APC Smart protocol driver 3.1 (3.8.0-3727-geade014bef)
APC command table version 3.1
Unable to open /dev/ttyUSB0: No such file or directory
Things to try:
- Check ‘port=’ in ups.conf
@PAVazquez I have the same behaviour .
I have tried “chmod g+rw /dev/ttyUSB0” but it didn’t help me.
usermod command is missing in Hass.io.
Did anyone try the NUT addon that @frenck and @dale3h are adding to the community repo?
Its not released into the repo yet, but I expect it would be possible to clone as a local addon or to add it to another repo…
For now I will be using the forked repo linked by @MichaelSchemmer.
I’m unable to get the addon-nut in the Community Has.io repo to work. This is the error in the logs:
[cont-init.d] 90-upsdrvctl: executing...
INFO: Starting the UPS drivers
Network UPS Tools - Generic HID driver 0.41 (3.8.0-3727-geade014bef)
USB communication driver 0.33
No matching HID UPS found
[cont-init.d] 90-upsdrvctl: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
I’m able to get NUT setup on a separate RPI without any issues. It looks like the add-on can’t find the USB cable attached to the RPi. This is using a CyberPower UPS. I also have a Aeotec Z-Wave USB dongle attached to the same RPi3… not sure if that might a factor.
The other repo works fine (for me)
It doesn’t appear that either repo is working colindunn/hassio-addons or hassio-addons/addon-nut (or just isn’t visible in the add on store).
Any thoughts on how to install?
I installed colindunn’s repo last week. Its working fine for me.
You need to add the repo before it will show it the store:
@hijinx, I have installed it in the past, but isn’t available and is erroring.
Am I missing something?
The repo owner needs to update the config.json to add:
"arch": [
"aarch64",
"amd64",
"armv7",
"i386"
This is mandatory for hassio addons now.
I had the same error. It was solved by powercycling the UPS.
