Just an update for you; we have launched a couple of new 2-way rotary dimmers.
These are the RD1, and the RD1-Pro. Both are compatible with our RD1C companion dimmer, but the RD1-Pro can also be set into remote mode for smart bulbs, and dual purpose mode to control both the wired load (via Home Assistant or other supported platforms, not Philips Hue bridge), and a remote device (using the knob).
We are currently taking pre-orders.
If you would like some more information please see our launch page and our category page: Launch page RD1 range
And of course we’re here for any questions as well.
@Candeo I’m really interested in this. I love the C202 as it’s like a regular dimmer that anyone can use, but I want to be able to use smart bulbs to change colour temperature during the day (dim-to-warm bulbs seem like a deadend). I have a through lounge with 2 lights and am wondering how the controls would work with a RD1-Pro and an RD1C. Would they both dim both lights by default? If I wanted to control a specific light from either the RD1-Pro or RD1C, how would that work?
these look great - I actually was just in the process of ordering a bundle which was discounted 20%, but when I went to pay it removed the discount and now I can’t see it on the site anymore, has the pre-order discount been discontinued or is this a glitch?
Also - if not running in dual purpose mode but running via the remote, will it run via the Hue bridge?
This is a great addition for the European market! Can’t wait to try it out.
Could you kindly clarify what are the input/output clusters exposed on each endpoint in each mode? I’m curious if the RD1 Pro will be able to bind directly to zigbee bulbs.
I’ve been trying to find the size of the new RD1 without the wallplate, is it published anywhere? The wording of what I can see suggests it’s not as deep, is that the only measurement change? I’ve been hunting for a smart dimmer module I can fit two of into an existing wallplate (due to the house using the same style everywhere), but so far things like the 202 just seem ever so slightly too wide to fit.
I have bought a couple of RD1-Pro and have them connected up to standard bulbs and integrated to HA via Hue. I regularly find that they come on at 1%, rather than at the last level. Is this by design, or is it a fault. It’s causing problems with Wife Approval, so much that I’m considering replacing with C202 if I can still get them. I have C202 elsewhere and it works fine.
While we have heard of this issue before, it hasn't really been common enough for us to pin down a definitive diagnosis. As Roger mentioned, his issue seems to have cleared up now, so it may well come down to the individual setup and scenario.
Hi, I have a number of single dimmers around the house and am currently moving things around.
Do you have any idea when you will have stock of the 2-Gang Faceplate in your candeo.io store, as it would allow me to combine 2 of my current dimmers into a 1-gang space?
I suspect you're referring to the faceplates for the C202/C202N dimmers.
If so these won't be coming back into stock, but you can use the Hager WMDRP2KIT 2-gang dimmer switch plate instead.
