Thanks mituns,
your solution now works for Synology with NFS.
Important was to use at Synology client definition the IP adress and not “homeassistant”. The name couldn’t probably not been resolved (other clients like “solaranzeige” works fine).
Don’t forget in the end to go on HA to Backup and change (by using the three dots at the upper right corner) the standard backup path to the new created networks storage because it will stay directed to the local card otherwise! What is the list usage (Backup, media,…) in the network storage dialogue good for? Bug or feature?
With Samba Backup it was possible to say keep e.g. only the last 10 backups.
I am wondering how to setup this now with the NAS Backup functionality in HA?
Has anyone a solution for that?
My GUESS is no. Unless you can setup a share on the mycloud for full anonymous access. The problem is Hassio does not have a place to enter a uesername and password yet.
I would really recomend a Synology DS 220+ 300 bucks without a drive. It can do a lot more than the WD Mycloud. I added ram to mine and actually run HA in a VM on it
Mycloud does work, I have HASS set up to backup to my EX2 ultra and it works fine. Synology are probably better, they are certainly more popular and seem to be more capable but if you can get an EX2 Ultra for a good price know that it will connect to HASS.
For everyone here who has trouble with connecting the NAS to HA via Samba and the above solutions doesn’t work:
Try to install cifs-utils on the HA-System, else the HA system can’t mount a samba folder
Hi, I have Home Assistant installed on Raspberry and a Synology DS214 Nas. What could I use as the easiest way to schedule a daily backup?
Easier because I’m not very expert
Thanks, that helped. Couldn’t get NFS to work, but CIFS with protocol set to 3 worked. I have now moved my backup folder to a “Backup” shared folder on my Synology NAS.
Trying to add a network share to my Synology NAS for backups. It keeps failing with that unhelpful message:
Mounting Backup did not succeed. Check host logs for errors from mount or systemd unit mnt-data-supervisor-mounts-Backup.mount for details.
I tried everything that’s suggested in this thread, but nothing does help. Did someone figure out where the error message is referring to? I’d love to know where that “unit mnt-data-supervisor-mounts-Backup.mount” is, so I can look for details there.
Phew, I’m relieved. You see, I’m no rocket scientist…
That said. “the host logs” still doesn’t ring a bell. Can you point me to some documentation where is explained what “host logs” are and where I can find them?
