I’m currently building a house. We want to have home assistant running much of the home automation. I am currently at the drywall mudding stage, so too late to run new wires, but need some advice and help with some questions. Learning the Hassio system now at our rental (with a few of the items to be installed at the construction) before implementing in new house.
So far here is my equipement
- RPI3B+ with Hassio
- Aeotec ZWave Gen5 USB stick
- (16x) Homeseer WD100+ wall switches - master bedroom, common areas, exterior lights.
- (1x) GE zwave motion dimmer switch with 3 way add on - master bathroom for night/time based motion activated lighting.
- HVAC - Carrier Infinity. Unfortunately they don’t play well with aftermarket thermostats and I didn’t know this until after it was installed. Great unit, just not very friendly with non carrier devices.
- Garage doors - Liftmaster with MyQ support
Question #1: WIFI
I have no IT experience and am probably screwing this up, can you check my work? I wired lots of CAT5E cable throughout. I believe the proper way to manage hardlines is… Fiber/Data into house from road >>> modem >>> 24 port unmanaged switch >>> then to a) all the cat5e wall outlets & b) three points of wireless signals.
Should the Hassio/RPI3b be attached to the switch for best “hassio.local:8123” access?
Is it better to have the 3 wifi nodes be mesh network (ie google wifi), or should I use 3 wireless routers and setup individual access points with the same settings since they are all hardwired anyway? I don’t want my family/guests to have to change any settings besides adding a single network one time and then be able to roam throughout the house maintaining good signal/data transfer.
Can you recommend a device? Other than having good data rates and signal and ease of device handoff between AP/Nodes, I pretty much just require the ability to assign static IPs, port forwarding, and maybe running Private Internet Access VPN on the router rather than individual devices on the network.
Question #2 - Ceiling Fans
Great room is vaulted 2 story room, so peak height is at least 22’. I would like a high volume, low RPM fan that can integrate into HA via hassio and don’t really want another remote laying around. This means automating it or having a wall controller (I hate having excessive remote controls around and it seems like many now include a remote as the sole control). Currently the construction is electrically wired for the ceiling fant (regular electrical, not cat5) and has a switch box on the wall at ground level for it. What fan would you guys recommend or have had success setting up without excessive expenses or ongoing monthly subscriptions? It seems like most fans run $500-$1000 unless I go with Big Ass Fan and then they get to be a few thousand which is more than I want to spend.
Thanks for the help in advance. I have been reading this forum for a few months but decided to finally make an account to see if you can give me some advice from all of your experiences.
