I am stuck in same point with “hassos_rpi3-1.7.img.gz” image, tested with and without USB for WIFI. the hassio.local never load and my screen connected directly to RPI only indicate
welcome to HassOS
hassio login:
I cannot login too because I dont know wich is it. Do you know guys which is it?
you should not have to login.
Try to see if you can find your hassio i the router and use its ip address directly in the browser like http://192.168.1.145:8123
Some routers are hopeless at showing which host is what.
If you have an android device I highly recommend an app called fing which will scan your local network and present a nice list of hosts with their ip addresses, and a whole host[1] of other info.
Question, I see the 1.7 version of the image is out. If I use this, how do I upgrade the version later if 1.8 or 2.0 is launched? Hass itself is ok, but I take it the HassOS would like some upgrades as well. Just a sudo apt get upgrade?
Limitation 64bit
The 64bit version is under development by RPi-Team. It work very nice but it could have some impacts. Actual we see that the SDcard access with ext4 are a bit slower than on 32bit.
OVA
The OVA stay for open virtual appliance. Currently we had remove the ova files and publish a vmdk virtual disk, until we have better OVF template to generate our OVA. This vmdk work with (maybe you need convert the disk):
I went flawless on my headless Pi 3B from resin to Hasses without any issues. I have chosen the 32-bit version, since the 64-bit is still in development. It just takes some time it from booting until the web UI comes up.
Now I want to connect my rfxtrx433e which means that I need to specify the serial port. I did not find the serial port under /dev. Is Support for USB Serial devices missing in Hasses or was this moved to another place?
